Hey guys,
I am getting so confused with all the different turbo kits up on the market
and i was just wondering if anyone could help!
Firstly I've got a series 1 r33 gtst and I also know I need all the associated mods to support the turbo set up, which isn't my problem!
This is my goal is to have around 250-300 rwkW.
I don't really care about driveability or traction, I just want power!
These are the kits/turbo's i'm looking at:
Trust tdo 6 20gc
HKS 2835
T04 E
To4 s
Apexi rx 6
Any advice would be greatly appreciated, even other types of setup or whatever!
Thanks in advance! :D
https://www.sau.com.au/forums/topic/60617-whats-the-best-turbo-kit/
This is all fine and dandy,but, are you prepared to pay for the forged internals when the motor goes bang?
The HKS GT-RS in t3 exh flange for rb25det is a proven recipe for your power needs.But this turbo is an internally gated turbo.And depending on wether or not you want an internally or an externally wastegated turbo is totally up to you.
As I said before (I also know I need all the associated mods to support the turbo set up, which isn't my problem)! :D
Anywayz what I wouldn't mind knowing is, what would the advantages and disadvantages are of an external wastegate.
My thinking is a HKS 3037 setup like Steve (SA)...or a HKS 2835 setup like B-man posted about:) keeping in ind these guys had cams etc, but Steves was on a std RB25 bottom end.
Ive also read/heard about great results with a TD06-25G on a std RB25 bottom end with cams, and the kits seem to be a bit cheaper 2nd hand, and when buying 2nd hand if there happens to be something wrong with the turbo then the get out of jail price of a rebuild is much cheaper with a plain bearing turbo asa opposed to Ball bearing:)
plain bearing repair - 300-400
ball bearing - 1000
ive had both and i cant honestly find a difference when driving with one
there are plenty of turbos to choose from, it all depends on if u want response or lag
sorry for the late reply! :Oops:
Well what I want is a car that is fun, Well I mean, I don't have a spacific purpose
for it. I wanna drift, Drag, Whatever just want to experiment with the car!
As for my budget, maybe just over 13 thousand keeping in mind that I'll be doing most of the work myself, sort of as a hobby (have company car so it doesn't
matter how long it's off the road).
If anyone has any allround setup suggestions(internals, fuel systems etc), feel free to let me know!
Or whatever you guys may be running in your cars and type of power output,
Drivability, Whatever!
Anywayz guys thanks again!
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
