G'day all,
I was just wondering....... if I install an air/fuel controller ie SAFC with an atmospheric BOV and have it tuned accordingly will the mixtures still run rich due to the air flow meter being tricked by the BOV? Is this also the case if I have my car tuned with a Power FC?
Any response would be appreciated.
Cheers :D
https://www.sau.com.au/forums/topic/60639-question-about-bov-and-fuel-mixtures/
how are ya? got this of nengun website, hope it answers ure question...
The second-generation S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The S-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
Thanks for the reply mate, I think it sort of answers my question but I think even if you tune the mixtures to certain rev ranges the atmo BOV will still trick the standard computer that the throttle is still open, but I dont really know...... I think the go is simply fitting a plumb back BOV.
:headspin: :headspin: :headspin: :headspin: :headspin: :headspin: :headspin:
You'll only run rich for a second until you open up your throttle again & then the airflow calculations will be correct again. Its nothing bad or dangerous, but may be annoying because you'll get stalls easy after venting out your BOV. I had to change my driving style 'tap the throttle after venting the BOV' to stop stalls.
Thanks for the response mate, you are right it is the the stalling that annoys me especially when you lose the power steering.... so I have also adjusted my driving style accordingly, however I would rather drive without bliping the throttle (after venting). So even with a safcII and mixtures tuned, you will still run rich for a moment and stalling will still occur? If so I think I will change my blow off valve to a plumb back before I install my A/F controller. Do you know if this would occur with a power fc and atmo BOV?
Yeh I'd imagine there wouldnt be any difference with the power fc, you'll still get stalls with an atmos BOV. You'll be fine with a plumback so just get one of those if it suits ya.
Only way to fight the stalls with atmos BOVs i believe is with a SAFCII. I actually have one of these, got it dyno tuned but i dont think the feature which is meant to help stop stalls with atmos BOVs has been tuned. There might be that function on the Power FC too?
I think the question would be to find somebody who actually has that feature on the SAFCII tuned & working!
Might just get a plumb back, bit sick of the sound my atmo makes anyway.... too loud.
Thanks again
You can do it with an SAFC but is it is very tricky and doesn't always work. This is because you have no control over ignition timing and that helps to hold the idle. Power FC's have adjustable idle speed as well, so you can add a few rpm which helps.:cheers:
did any of you guys notice poor fuel economy with an atmospheric BOV?
Not me, the "richness" is only for a tenth of second. Just enough tot stuff up the return to idle, but not really very much compared to the fuel you use in normal driving.:cheers:
I was plagued with the stall and unstable idle problem prior to my PFC upgrade
PFC doesn't seem to have problems with the atmo BOV on my car, altho my set-up is a little different to most with the stock re-circ BOV not being removed when the atmo BOV was added (don't ask me .. the car came from Japan like that). But I am happy because I don't have the huge 'Pssstttt' sound when it vents, as I see it it's assisting the standard BOV to vent quickly ( I could be wrong .. wouldn't be the first time :)
If it ain't broke don't fix it is my motto... so I have not bothered to remove the standard BOV
  • 2 months later...
Not me, the "richness" is only for a tenth of second.  Just enough tot stuff up the return to idle, but not really very much compared to the fuel you use in normal driving.:)
My car is running the stock BOV plumed back into my intake. When I shift from 2 to 3rd or 3rd to 4th I get what feels like lag but my boost is @ full boost (14 PSI) the car takes a second (more like 1/2 second) then it takes off. I am getting very rich readings on my A/F moniter. Since it only reads 10.1:1 I don't know how rich it gets but I feel this overly rich condition is why my car bogs between gears. I have even tried flat shifting but the A/F's still get rich. There doesn't seem to be anything I can do with the PFC to correct this. Is there an electronic device that will solve this problem?
I assume that means it returns the air between the AFM and the turbo.
That's impossible, the BOV has vented the pressure. Either you have a very slow reacting boost guage or the BOV is not venting properly.
That's a very long time, there is some delay in all cars, but 1/10th second is more like it.
How fast is the lambda sensor? I have yet to find one that is accurate at 1/10th second.
Sorry I don't understand what this means
10 to 1 is not overly rich, that's what it would run standard.
They should be no richer than when it is running at those rpm's. Do you have a dyno graph of the A/F ratios?
What have you tried so far? We have 5 cars running PFC's (from 225 rwkw to 415 rwkw) and none of them have this problem.
I don't even know what the problem is for sure. But I suspect it's either the basic setup of the PFC (injector lag maybe) or the tuning.
My best suggestion, post up a dyno graph of the A/F ratios, power and boost curve. Then list out alll the mods. There are plenty of smart guys on here with lots of Skyline experience, if we have the necessary data I am sure one of use will know the answer.
Ok. Lets start with the setup.
I have a T3/T4 56 trim stage 5 wheel. Turbo mounted on the stock manifold with adaptor box for external wastegate.
Motor is a series II RB25DET
Apex PFC
Q45 MAF
S15 injectors (What should the lag settings be?)
Nismo FPR Pressure is set at 38 psi @ idle under vacum.
Walbro high flow fuel pump.
3" turbo back exhaust (no cat)
17X9X3" FMIC.
Running 14 PSI
Car when 13.0 @ 112 running 12 psi.
For my wide band I have a tec edge (not sure what model but it's the older one)
I noticed even when I am not running the car hard between shifts my A/F goes right and peggs the meter. The meter on goes down to 10:1. I have the car street tuned to run 11.5:1 or richer. See very little knock on the moniter (only jumps to 25-28)
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
