r they good?
i am in the market for dump + front upgrade.
i've looked around taka kaira website and found front pipe, but couldn't find "dump" pipes.. but they have dump pipe looking thing called "extension kit" in wastegate section.
can anyone confirm that these r actually what we call dump pipes in australia? (got a email from taka kaira, and the guy who sent me an email said he's never heard of the term "dump pipes" in japan.. apparently no-one uses that word in japan...)
Thank you
https://www.sau.com.au/forums/topic/6064-hks-dump-pipes-and-front-pipe/
how do you tell whether a front pipe is street legal or not... some front pipe from certain brands require you to remove your cat but some other brands are only up to where the cat is so you can still use your cat and not doing something illegal
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
