  • Replies 300
Posted Images
mine made the noise ALOT more after i installed my front mount. i also have a APEXi dual chamber BOV and didn't adjust it for the first run after that and it sounded really good but i wouldn't leave it like that.. you'll kill the turbo.
you think about it, the turbo is spinning one way then when you get off the gas all this air has to go somewhere. that place is back through the turbo which is spinning the other way.. thats when you hear the chop noise.
Peformance wise, wouldnt it be better to have a complete plumback system wired to flow back just after the airpod? By doing that wouldn't it reduce turbo lag?
Thats an interesting question. Although, it does sound logical......
Has a plumback system been designed this way? Or anybody using this setup?
Steve.
Yes thats right.
My car came with the factory valves blocked and it was SHIT.
It fluttered and was laggy.
So I had the plumback reinstated and now it works BETTA.
I can't believe that you care about
some poxy sound resulting from a flawed setup, rather than
having you car working properly.
Why don't you make a recording of it and just play it on your stereo?
Or is it for everyone else to hear.
as some were asking before, you need an aftermarket air filter to HEAR the flutter because it has less restriction. you may even have the same flutter with the stock air box, but you just cant hear it. but the sound does come from compressor surge.
r33zilla : you will NOT get flutter with a HKS ssqv, believe me i've been there done that. the ssqv was designed to elimnate EVERY possible effect of compressor surge and flutter, its just the way its engineered and designed. you will only achieve the faintest flutter, which you will barely even hear.
hope that helps
if u have a stock bov, and an air filter with a large surface area such as an HKS or TRUST one u will get little flutter.. But if u got an after market BOV running stock boost and u got an air filter it will flutter pretty loud... The reason y u dont need to remove ur aftermarket BOV is cause the spring inside it is really tight and only releases when ur on high boost (8-12psi or whatever).. The Stock BOV has a very soft spring... Once u get an airfilter ur car should flutter at low revs, but once u get above 5000 rpm, it will go tshhhhhh the normal sound which is normal.. I had a stock R33 and did that and got alot of flutter.. When i put my front mount on it was even louder, and when i changed the piping to stainless steel igot even louder lol!!! It is pretty mad, but be careful with what air filter u buy cause some dont filter as good as others.. But if u just want the sound, defenitely buy a HKS mushroom or a TRUST Arinx one for abt 100 bucks second hand they always for sale.. And changing the stock air filter to the pod is very simple, shouldnt take more than 40 minutes if u got the right tools..
hope that helped..
Rob
ahaha this question plagues every forum.
To enhance your 'Flutter'
you will need a AfterMarket POD Filter.
an AfterMarket Intercooler will help amplify the sound
Different sized turbos will also depend on how loud, how deep, how high pitched
The big thing, is having steel piping from the turbo to the pod filter. Usually its plastic from the factory and people rarely change it as its not really necessary... but changing this pipe to a steel one, will help amplify the sound.
People will argue to death that it kills turbos and whatever, and its more laggy all kinds of stuff... and really, its horses for courses - whatever you prefer.
I had a bov on my vl turbo, the spring in it died and the bov was useless (could not hold more than 7psi boost and would open up sounding like an external wastegate but losing all horsepower), that sucked... it was a TurboSmart Type III. after that i just took it off and had the hole welded up.
I had a bov on my R32, and it wasnt placed properly (it was not hidden)... stuck out like dogs balls, and as soon as a cop pops your bonnet, they think its christmas when they see it, because they dont know fcuk all about cars, but they know what bovs look like and they know it shouldnt be there...
I remember i told a cop it was standard, argued the point and got away with it. But i removed it anyway.
Bloody posers.
It's full sick.
I have a s15 stock re-circ. If take your foot off the accell quick enough when on full boost you still hear crazy woosh for some reason (I thought that wasn't meant to happen with a re-circ)... this thread makes me worry now maybe it's not up to the job but I'm only running .8 bar or so. :confused:
I still don't understand why people want these noises - just get a bigger turbo and make noise with the wastegate :(
This thread is gay.
The "flutter" sound (not to be confused with the sound from a sequetial BOV) is compressor surge, it happens when the compressor is operating severly out of its efficiency range, it is not a good thing.
So when I hear a car drive past fluttering between gears, I dont think "fully sick man", I think "that car is set up like shit, and that tool thinks it is great"
If you want it to be louder,
1)block up the BOV (causes the compressor to operate at essentially zero flow when changing gears) ie; way out of its efficiency range,
2) get a pod filter - stock box is designed to muffle the sound,
3) FMIC - larger volume of compressed air for the compressor to work against (at zero flow) during gear changes.
All that should reault in a longer louder flutter to tell people your car is fu(ked.
Sorry if I have offended anyone.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
