The apexi's aren't as loud as some of the other brands. Everyone has them, so i'd assume they're the most popular choice. I have a DRIFT filter on mine, it flows at pretty much the same rate as the apexi's and is quite a bit louder (main reason i got it was coz its a tight blue colour, goes with intercooler joints and my yellow paint) Apexi ones would probably filter dust and crap better though.. Still $30 for a DRIFT one $150 for a apexi one.. and your probably gona lose power over stock box, idk just some stuff to consider
  • Replies 300
Posted Images
Flutter sounds good on some cars not all... some cars sound absolutly f*king annoying! My friends s15 has a big ass apexi gtr intercooler i cant remember how thick the core is but i think its like 110mm? correct me if i'm wrong bout the cooler but it sounds awesome.
The quick flutter noise (like alot of skylines i've heard) and a few s15's s14's i've heard and 180's sound SHIT with the quickets tutututut you'll ever hear and then a pop after the gear change lol cos of the added richness which makes u just wana kick the owner in the teeth... besides they wanted to attention didn't they?
But flutter on standard skyline ceramic turbo = no go zone unless your looking for an excuse for a bigger turbo. :(
My 2 c.
But flutter on standard skyline ceramic turbo = no go zone unless your looking for an excuse for a bigger turbo. :P
My 2 c.
Then why didn't mine come with one from factory? (hr31 coupe)
1989 cefiro RB20DET NO BOV
1989 R32 skyline RB20DET HAS BOV
WHY OH WHY?!?!!?!?!?!?!?!?!?!
Because the cefiro uses the redtop motor with a different rocker cover, and back then they didn't come with a bov from factory.
BOV, from the factory, is only there to keep the emissions gods happy
Cefiro, as pointed out, started production earlier than R32, so different emissions rules when it was designed
That's also why the Ceffy RB20 has bigger cams than the R32 RB20
For maximum 'dose' noise, use a hardpipe between the inducer and the afm, also, the bigger the cooler, the louder it will be
Apexi pods can be bought for $98 delivered from CJ Motor (a nissansilvia.com sponsor), straight bolt on for RB20/25 and Z32 AFM.
I have seen an independant review between apexi, blitz sus, hks mushroom and K&N - apexi had best flow and much better filtering than the others. Well worth the money
Yeah Ive read that review aswell and i think it was covered on ns.com too im also a memember on ns.com ATTN gettin the filter off CJ
Heres a pod filter test if it helps anyone. i dont know if you have already seen this.
i also had the same problem with some one telling me the wastegate makes a fluttering noise. it was like talking to a god dam retard.
http://www.mkiv.com/techarticles/filters_test/2/index.html
Tom9999, that's the one, I expecially like it because it doesnt appear to have any affiliation with a particular manufacturer (or advertiser), and they test REAL power gains, as well as filtration.
Nor sure about centre lines, but bigger lift and longer duration. I saw it on a japanese website that had a comparison of nissan engines' cams over several models...
The ceffy runs bigger cams?? >_<
Just different centerlines or increased duration/lift also?
Redtop cam profiling is a bit more aggressive than silvertop. Slightly more duration and lift i think(not sure if it's exhaust side only *shrugs*). The figures are somewhere here on the forums in a thread, just can't remember how old :laugh:
aaanyway. If you want a decent fix, give me your BOV flange, i'll butcher the shit out of it with a welder, and charge you an arm and a leg for it >_< no need to worry about aluminium can bits if you are really that concerned.
Seriously. Just go to an exhaust shop, tell them you want them removed, and sell the thing/things.
I have on hand the redtop cam specs but aren't the Ceffy's silver tops?
R31's were redtops? >_<
yup, import 31's were redtops. Cefiro's are silver tops.
The red top came in two versions, NICS and later model ECCS.
This is where its interetsing, the cefiros were infact redtops with a silver coloured top. The internals, turbo, ecu are all redtop ECCS spec.
Guest
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
