  • Replies 300
Posted Images
yeh i got 20cm 2.5" stainless steel intake pipe. afm on cooler pipe. its on the turbo pipe, which isnt recommended (as its hot air, and afm reads inaccurately), but i dun see any room on the cold pipe to mount the afm. didn really eliminate backfiring, til i got stand alone engine management.
bov blocked off..got a whole new stainless steel pipe made for it
doses n spools like vl turbo..alright to show off, but the high pitch dose really gets to u after a while..unless u got loud music inside the car :)
this thread is a joke, to all the morons obsessed with the fluttering noise, the only real flutter that sounds any good and is the cause of something useful comes from a wastegate, preferably an external one off a big turbo. Otherwise dont bother trying to obtain the noise through other means because it never sounds the same and it never sounds cool, its merely an imitation of wastegate flutter. People talking about thick intercoolers and huge pods giving the best noises rofl...its hilarious. Why would you want a 110mm thick intercooler on a car running a stock turbo that cant possibly flow enough? Oh to get the flutter lol. Sad that this thread only comes from last year, you'd hope its from like 2003 or something when imports were new and people wanted to make them "fulleh sik" with flutter noises.
Edited by 33NIZ
LMFAO...
erm you are taking the piss aren't you? RE: Real flutter from Wastegates
LMFAO...
erm how so? What exactly do you think a wastegate sounds like when you back off, im not talking about when its open on full boost obviously.
from one of HPI movies HKS street drag meeting... all the gtrs had fluttering when backing off its real fast and sounds way better than a bov flutter...but i dont think this was from bovs .. could be other factors...but very lound and fast flutters
but i was also under the impression that any aftermarket bov will flutter at low rpms (or before you hit boost) ? not quite sure... please do advise me
Edited by DaGr81
Dude, please... do us a favour
www.howstuffworks.com
Go and read, understand, and re-read just for out benefit so you can understand the basic function of car parts
And then read this entire thread as its probably been covered a dozen times.
An external wastegate does not give you flutter. ;):no::no:
Regardless of... backing off, on boost, cruising with your homies, having seks with your mrs in the back seat.
External gates have absolutely nothing to do with "flutter".
Dont try and agrue the fact that it does, otherwise ill even link a video of my car and you can hear for yourself that there is no flutter due to a wastegate.
Simple.
Well its been around 4 months since the last time I blocked off my BOV for some fully sick flutter. The last time I did this my car kept stalling and I could always smell fuel so I changed it back. I decided to try it again a few days ago and so far my car has been running really well. I used the old coke can trick and blocked off the Manifold pipe. My car hasnt backfired since and seems to be starting up alot easier. The gear changes also feel alot quicker. If my stock BOV is getting old can it casue the car to backfire and not start properly? Flutter is fully sick, lol :glare:
QUOTE(R33HVN @ 19 Jan 2007, 01:46 PM)
But flutter on standard skyline ceramic turbo = no go zone unless your looking for an excuse for a bigger turbo.
My 2 c.
Then why didn't mine come with one from factory? (hr31 coupe)
You should give Nissan a call and ask em...
this is a quote from http://en.wikipedia.org/wiki/Wastegate
Wastegate chatter myth
The noise is in fact the air compressed by the turbo passing back through the compressor housing of the turbo after having hit the now closed throttle plate.
A blow-off valve (BOV) will usually eliminate this noise, but in some cases, i.e. where it doesn't open fast enough or is setup to only react to high boost, some chatter will remain.
Turbo Flutter = Fully Hectic ... remove the BOV and seal the hole up my friends.. it does no damage to anything and that's a promise.. the only reason nissan even use BOV is due to old men not liking the sound when they drive the car.. they didn't put it on there to protect anything but our ears.
ceramic exhaust or compressor wheel?
bovs i believe came factory on turbo nissans late 80s
so like 89 i think the mainstream run for the bovs
as nissan (probably) found they increased turbo reliability and emissions
the bov was fitted on factory cars for a reason
take it off or block it if you wish, but its doing some damage
how much i cant say, but its doing some
the service life was changed after bovs were factory fitted
so there is obviously some justification behind it
Just out of curiousity how is it possible for air to flow back through the comp wheel? like im guessing it doesn't stop the impeller spinning, but how does it happen, does it flow back through the comp housing and whilst stopping all air slow down the impellor heaps or does it just travel around the impellor or wa? Was trying to figure it out the other day
I wish someone said that to me and backed it up with a "i'll highflow your turbo if it blows".
I just wonder how many people its happened to? I changed from a bleed valve to a EBC, put the boost back to where it was and blocked the bov to see how it would sound, then BANG. Both compressor wheel and exh wheel shattered, both wheels were ceramic aswell scared the shit out of me to be honest.
Guest
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
