  • Replies 300
Posted Images
the bov was fitted on factory cars for a reason
take it off or block it if you wish, but its doing some damage
how much i cant say, but its doing some
the service life was changed after bovs were factory fitted
so there is obviously some justification behind it
are you sure?
It was the introduction of BB around the same time?
A mates VL did close to 300,000km's with the std bush turbo running 12psi with no bov, he travelled almost 200,000km's in it.
I was talking about blocking it off, going to have a bit of fun on Friday night, then putting it back on. Its not like I'm running hectic boost, only about 7psi atm. Just wanted to know if I am going to be destroying my turbo or not.
Your Turbo will be fine :devil:
Ive gone through so many threads and read so much about not using a BOV. Conclusion is that it will not damage your turbo at all. At the most it will take 1 hour off the life time of your turbo, lol.
Block up your manifold tube and block the BOV with some metal or a coke can and listen to the fully sick flutter :devil:
this thread is a joke, to all the morons obsessed with the fluttering noise, the only real flutter that sounds any good and is the cause of something useful comes from a wastegate, preferably an external one off a big turbo. Otherwise dont bother trying to obtain the noise through other means because it never sounds the same and it never sounds cool, its merely an imitation of wastegate flutter.
:devil:
wtf...... seriously
ye i like my REAL wastegate flutter, not this fake stuff all you loosers have.
the best thing is i have 2 waste gates so i get the sound x 2.
Alluminium is a very good conductor of heat.
Anyway your right the coke can will work... bit dodgy though :laugh:
I can't believe this thread is still going, and that you still want your car to flutter.
My bad there. Wasn't all with it that day.
Anyway. As for worrying about aluminium melting, it has a melting point of over 600*C....
Nissan didnt use a BOV on the redtop 20's, and I know of PLENTY of people who are still running the stock turbos on 12+ psi on these engines, so, really its up to you. I dont run a BOV on my 25, and im not going to, dont listen anyone who feeds you the bullshit 'its gonna blow your turbo' story, cause it doesn't.
Edited by juddieR31
So if my RB25 is in good condition this will not blow my turbo running at 7psi boost? I am interested as both sides have put up a very convincing argument and I want to know for good what the deal is.
Both sides :P theres like one guy saying it'll blow up, and saying that his blew up the day he changed it over.. No one else has recorded anything else of the sort, and the amount of people running big turboes or stock turboes on hi-boost without BOV's shows that if theres any extra wear it's very hard to notice.. It's certainly not going to cause any short term problems
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
