in conclusion, they aren't that bad for your turbo as evidenced by the many workshops that do it to their cars, however, no skyline enthusiast with half a brain would do this to their car for fear of being mistaken for one of the stereotypical losers that actually do do this to their cars to make them sound 'fully sick' as that is purely not what driving a skyline is about.
my 2c
  • 2 months later...
  • Replies 300
Posted Images
BOVs are f*king gay, they sound like a gay c**t farting
a shit load of hi po rotors my mates have had didnt have any BOV and same with my mates other cars although most had massive garrett turbos
my new engine isnt going to run a BOV
IT DOESNT MATTER....
Compressor surge does jack crap to your turbo... it wont "blow it up", your turbo is working harder compressing the air than coming offboost.
Please get a timing light with any car running a high-mount on a dyno, and SEE what happens to the compressor blades when the "big bad cooler noise" happens... haha yeh man... the turbo blades stop/start spinning backwards.. haha.
FFS stop reading useless advertising crap off of the turbosmart F.A.Q
One of my best freinds (drives a straight gas VL turbo GAS-747) runs a 10.80 all day/daily driver, runs 30PSI driving over 2 years without ANY problems with the turbo at all. (GT40)
Look at most sub 10 sec turbo VLs... what a suprise... no re-circ B.O.V.
Really as posted above, its horse's for courses. Whatever you prefer, i have NEVER heard of a turbo destroying itself through compressor surge and if it was such a major issue for turbo reliability most TOP STREET drag cars would be running them. (Bres, rajab come to mind)
if your after turbo reliabilty, run a R34 NEO or GTR oil & water pump... that will save your turbo before a BOV. But whatever floats your boat mate! :D
Cheers,
Trev
i had a ssq bov on the car when i bought mine, and it must of been adjusted to tight, and the ssq sound i was hearing was flutter, but i was none the wiser as i thought it was the ssq, i only found out due to i bought a greddy type s (knock of) and put it on and it also was to tight and was still making the flutter, played around with it for a while and still can not get rid of the flutter, i got a high flow turbs but f_&* knows whats goin on, maybe cos they were both cheap knock ofs, the flutter has done no damage to my turbs though, ..oh well thats my rant
this coming from a man who has a BOV on his R32?
very amusing...
no.... the BOV was removed because its useless just gets cops attention and book your ass.
If you run a BOV just leave the standard one. But when you go serious power remove the BOV>!
I was under the impresion that no bov was louder than having one? Thus less attention for a factory fitted item. <_<
took it apart and it had 2 springs in it, i would say a high and low boost spring in it, kept the soft spring in it as only runnin 9psi and hopefully stops reversion,
This is correct. Plumback BOV's were fitted on skylines for emmission control...
I think they are alright. They're one of the reasons I like turbos...
My 2 bob.
I haven't looked in to it enough, but the way I see it when you've got compressor surge you're applying a force to the blades that it otherwise wasn't designed to take.
The force itself might not be as strong as when the turbo is on-boost, but the compressor wheel is designed to take load in that direction.
The air might flow a different way but the force is in the same direction.
My 2 bob.
How does fitting a BOV correct emissions? The standard skyline bov's simply recircluate back into the intake system. Without a bov the air is still in the same location. I don't see how it "helps emissions". The BOV is simply there to prevent compressor surge when the throttle body is closed
Well....
The air in the plumbing has to go somewhere right?
It goes back out of the turbo (surge) and into the atmosphere, passing the airflow meter on the way which read some airflow and the ecu pumps fuel through your injectors giving you a black puff of smoke.
If you have an atmo BOV, the turbo keeps sucking air and the air flow meter reads the air - etc.. see above for the rest.
A plumback keeps the air circulating through the plumbing,after the airflowmeter, the aflowmeter doesn't register any airflow and there is no polution.
You're going to have to unpack that for me, and explain how air flowing in a different way can also be applying force in the same direction as when its not flowing in this "different" way.
well the stock bov noise on my rb25 was pissing me off, so i made up a metal gasket blocked it off, and now my car flutters, i only run 10psi and so far no damge, and it dosnt really slow the turbo down at high revs when making boost
Guest
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
