AndrewD, perhaps you should do some research, instead of listening to BOV salesmen and the rest of the speculation posted on interenet forums.
Pray tell why the compressor surge is harmful? it isnt, the turbo is not a positive displacement pump and the fact is that turbos actually speed up when they surge, as there is no more load on the compressor wheel.
I have tried with and without, have just upgraded my turbo after nearly two years and 10,000kms, with a large amount of track work - NO bov and the turbo is fine
perhaps the engineers who have chosen to run NO bov in the past know more than you (hard as it may be for you to accept) Perhaps there is also a reason Mazda state in their workshop manual for turbo engines that the bov is there for emissions purposes - absolutely no metion of protecting turbochargers from imaginary gremlins
lastly, if you dont want to listen to others on here, perhaps you will listen to the words of Simon Gishus, who actually has done research, not just read articles on the internet like you
From Auto speed article
In Part 2 of our interview, we speak to a leading industry expert Simon Gishus about Nissan engines, Holden Gen 3 V8s, and directions for modifications...
What are some areas where people often make errors modifying their turbo car?
"The classic blow-off valve.
"The blow-off valve is designed as an emissions control device for OE manufacturers. It came about when smaller engines made more and more power using larger turbochargers and bigger intercoolers. As you close the throttle, the build up of pressure and the larger volume inside the intake has to go somewhere; it can't go into the engine because the throttle is shut. Instead, it has to do a U-turn and it comes screaming out the airflow meter. That creates the 'gobble-goggle' sound.
"The gobble-gobble sound is something the public has grown to love.
"The airflow meter is not all that smart and does not realise the air is going in the wrong direction; it therefore measures the air twice (once going into the engine and again going out in the wrong direction). The computer now tips in twice as much fuel as what's required, making it run rich - making it not pass emissions.
"Therefore, manufacturers fit a blow-off valve - or a recirculation valve as they are actually called. A recirculation valve opens when it senses manifold vacuum, returning the air trapped at the throttle body to between the airflow meter and the turbocharger. As such, the airflow meter does not take a double reading - the car now passes emissions.
"Unfortunately, we've had people ringing up and wanting the "audible gear change alarm".
""What audible gear change alarm?" we ask. "You know, when the Sierras were running around and just when they went to change gear it used to go whoda-whoda-whoda" they tell us.
""No pal, that is the dump valve..."
"Some people do think that at the absolute upper extremes of boost levels - about 30-plus pounds - the blow-off valve does, somewhat, save the compressor wheel and shaft from trying to rotate backwards. It doesn't actually rotate backwards at all - all you're hearing is cavitation. What happens is, you've shut the throttle, the turbocharger is doing 100,000 rpm and now has a boost spike of 50 psi. Because it's working in a higher region than what it's designed for, it slips; it basically does a skid like a car tyre does when you dump the clutch. That's the noise you hear - the whoof-whoof-whoof is the air doing a skid."
the article does go on, but the above sums up nicely the fact that you AndrewD, should practice what you preach, and not just come on here and sprout your psuedo technical (and flawed) babble, and refer to people as 'idiots'
/rant
  • Replies 300
Posted Images
I have few points to rebutt,
-The physics do suggest it can happen. In applications where the throttle is POST compressor, when it is closed you increase the pressure between the compressor and the throttle. As pressure increases, pressure ratio sky rockets. Most compressors for road cars (not race cars especially F1) operate with a maximum pressure ratio of no greater than 2. Above this surge occurs (but not only under this condition). Surge also occurs when the throttle is closed, the compressor cannot 'push' the air any further and it reverts and flows over the tips of the blades. As JC Marhsall stated earlier this creates vibrations in the blades and coupled with high hydrodynamic pressure loadings on the blades (at a distance from the blade / wheel interface) this causes them to bend or shear. It happens, go to garrett they have plenty of compressor wheels on display that have failed due to surge.
-Racecar engines that have not failed. I call dibs on this one. Lets define a racecar shall we. I think you will find that most racecars especially in the elite class, are often rebuilt after every race and the majority of their parts replaced. Not to mention that typical race cars with turbo applications run high boost (higher pressure ratios ie around 4 or 5) this means that compressor wheels are larger, and have a greater saftey against failure. However,
I would like to point out that most of the earlier F1 cars had PRE compressor throttle. This means that while the the throttle is closed, still increasing pressure ratio, the engine is unhibited to breath the pressurised air. And this surge doesnt occur. Rather now you get cavitation. The need to run a recirculation valve to 'raise the inlet pressure' is not so pronounced and typically improved seals are all thats required.
-Before you start complaining that people are getting all upset about falous claims, take the time to read many of Society of Automotive technical papers on this 'phenomenon' as you put it. Why do you think most compressor applications outside of automotive use are constant throttle / load?
I'll leave you with something to think about, being as it is i have access to a race engine using a garrett GT15v (yes its small, but its also the very same kind used on the new porche engines) we have a shaft speed sensor and have clocked it at in excess of 200,000 rpm. Now consider that you have surge at a pressure ratio of 3. Almost instantaneously the shaft speed changes to 0. Now no matter how light that wheel is, there is a significant amount of inertia force on the blades which is tramsitted to the key and shaft.
So before you go all internet mechanic on everyone, do some research. Peace out.
How do you explain the equivalent of 650 1/4 mile runs on MANY Ford Sierra's running at Bathurst over 6 hours of an endurance race at 36+psi boost ?
Or the worst punishment of over 2500 1/4 mile runs on the typical Le Mans endurace racer during a 24hr race again at very high boost ?
There are many examples of cars that are far more highly stressed running the same old "shitty" turbos we use now days and not having ANY issues or instant failures.
Please turbos cant and dont cavitate - this is rubbish - Cavitation is a non issue in an air system.
In a fluid system cavitation happens when small air bubbles (in water) can be formed around the compressor due to a large pressure head or an overspeeding compressor for a certain flow capacity - both have absolutley nothing to do with an air based pumping system
The resulting air bubbles explode against the surface and can eat away a whole compressor!
The loads assosiated with WG only flutter are very very small (not enough to cause any adverse effects), that is why this was never an issue is years gone past, why is it only an issue now ?
Using the reasoning that race cars throw away the turbo between races is all well and good, just remember how much "work" they are doing compared to your average street/drag car and you will see it far out strips any other motorsport situation. That is why they call em endurance cars
Misleading marketing and value added sales are the biggest reasons, though this again is only my opinion and nothing more. I will choose to follow past history from the smartest brains in the world who proved their systems (in the toughest situations) rather than some hype rubbish printed in HOT4's for example
End of the day do whats comfortable for YOU, justify it how you like so long as you are happy and think your making the best choice. If your going to be paranoid about not running a BOV then its not worth it for you. :P
Im still laughing.
"Turbochargers cant cavitate"
Any rotating machinery can cavitate, especially air systems. The type of cavitation you described was what is experienced in centrifugal water pumps. Doesnt mean it requires water.
Btw those articles are by industry professionals. The same very people that design those turbocharger systems. Yes i understand there is an emissions, fueling related function of BOVs but its not their only function.
Ive got logged data that proves the fluctuation in turbo speed, so maybe Simon is talking about a different situation.
of course, you know better than simon.. silly me
and as for your comments about cavitation, perhaps you know better than encyclopedias, dictionaries etc - unless you are talking about 'a different situation' - just like simon
http://en.wikipedia.org/wiki/Cavitation
there are dozens more definitions available on the net too http://www.google.com.au/search?hl=en&...ation&meta=
ALL talk about fluids - perhaps there is a reason for that?
perhaps we all need to go back to uni - except for you of course
The kind of surge you are talking about is different to when you throttle off, as when you throttle off the exhaust stops spinning the exhaust wheel as well so the force is far less.
AndrewD what have you got to say about the factory produced cars that run no bov, my old 31 skyline came with no bov from the factory, its still had the standard turbo on it running 11psi at 106kms (apparantly) its was a little noisy but was still working fine and it fluttered all day long.
Edited by Rolls
air is classed as a fluid
a fluid can take either gaseous or liquid form
maybe when talking about fluid dynamics, but with cavitation, liquid is more specifically used (which is also referred to as fluid), but you obviously like splitting hairs, so what say you then to the following quotes
- The formation and instantaneous collapse of innumerable tiny voids or cavities within a liquid
- (noun) The production of voids in a liquid system due to extreme reduction of internal pressure
- The boiling of a liquid caused by a decrease in pressure rather than an increase in temperature
to quote but a few from a quick google definition search
Or are you now going to expand and say that as fluid includes liquid, there for incudes gasseous variations (bubbles forming within air)
And also, please point me to one external definition of cavitation that specifically states it can occur within a gas - you made the call, shame you cant back it up.
drives better imo - I originally removed it cos Bai suggested it was best for throttle response, he doesnt use one on his drift car for the same reason. The 2ic of signal also agreed that no bov was best.
Never looked back, never use one again - throttle response is much crisper, and pretty much instantaneous, especially when on/off throttle trying to control a slide
Idle, coming off revs (fuel cut recovey), etc, all perfect
Hey ppls,
Out of my own curiosity I blocked my BOV off today.
The sound.. well it does that vlt noise, its fairly quiet though as I run a stock airbox with a 100mm cai running in to it. So all the noise is out the front of the car.
Boost is also up ~1psi.
Apart from that, boost response is most definitely up. It boosts a hell of a lot earlier and on full throttle gear changes and part throttle back off's (i.e drifting) its definitely much much better.
Now for the down side.. :)
Mine for what ever reason suffered a few drivability issues.
Plodding around changing up at around 2000rpm with ~7psi being made initial acceleration in the next gear halt/motor die for a fraction of a second then accelerate as per normal, sometimes it would fart and blow flames on the gear change. :)
Driving up my drive way with a little free rev also saw the car stall.
But I'm sure the stalling issue could be ironed out with an adjustment of the fuel recovery point.
Apart from the low throttle low rpm issue; if I were to use the car for track or primarily drift, drag etc I would most definitely do the mod.
I'm certain bumping idle and the fuel cut recovery rpm would sort the occasional stall issue.
I'm going to drive around on it for a few days and see how it goes.
Your are 100% on the mark regarding response. Definitely much nicer through the hills.
unless this post is closed this thread will go on forever.
I think people should express there experiences WITH and WITHOUT bovs and then let the owner of the car make there decision.
Coming from a background of vl turbos and currently driving an r32 i really think bovs are unnecessary and if not having one does damage at ALL it must be very very minimal.
As for the turbo damage issue why not get the best of both worlds..just buy a cheaper small bov and tighten the spring really hard so on low boost it flutters and high boost it vents the air?(i think somebodys already said this)
my thoughts
cheers
Raz
Well not really.. The thread did die until I decided to try blocking off my bov.. I posted my experience.
After driving the car last night and today for in total a good few hours I so much like the less lag between gears and how much quicker it spools.
With a larger turbo that lags a little more I think no bov would be a good thing. In my case I'm going to have to go back to having a bov as its just too harsh when driving in traffic.
I'm 100% convinced running a bov actually increases gear change lag. It still freaks me out how blocking off the bov has removed that fraction of a second delay before it boosts again.
But unfortunately I can't handle the roughness at low 2000rpm gear changes when its making reasonable boost.
You rb20 and rb25 blokes probably won't experience what I'm seeing as if loaded up I get the boost in by under 2000rpm, not loaded up it comes on hard at 2000rpm, ~2200rpm with a bov.
Guest
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
