Show us your engine bay thread!
ok, here's mine on the first day I got the car after rego.
I've already done:
timing belt, cam gears, cam gear cover, greddy air diversion plate, and a little bit of tidying up.
should look nice when I'm finished.
  • Replies 102
...And yeah I know the GT-R badge is lame, looking to get a GT-S style replacement ASAP. Anyone know where I can get a good quality one?
Bugger it. LOL id leave it there as it seems to pi55 so many ppl off:) Plus you certainly have the goods to scare ppl when you try to put your foot thru the firewall.:rofl:
Bugger it. LOL id leave it there as it seems to pi55 so many ppl off:)  Plus you certainly have the goods to scare ppl when you try to put your foot thru the firewall.:P
:rofl:
The GT-R badge has been on there for almost 5yrs... I was supposed to get a GT-S badge when the grill and front bar went on 5yrs back! The panel shop said "yes we will source a GT-'S' badge no problems" I rocked up to pick the car up and that's what they'd fitted.
The car has claimed a few GT-R kills over the years. Had a good run with an N1 turbo'd (plus other mods - stripped interior etc) we both ran ~120mph TS. He got 2 cars on launch. I reeled him in a bit though.
 Share
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
    • Found some from 2009. The lobster bends were smoothed out on the inside with minimal gaps (perhaps 2mm) where the silicone joiners were used.
    • And if you have to drive it in a civilised (or excessively woke) US state, find a way to register and insure it in a redneck state, so you can roll coal in it without worrying about legalities.
