Today I got my new fuel pump fitted ... Bosch 910.
I also bought a front mount intercooler :(
Once I get the front mount and my VG30 turbo put on, and then get it tuned, what sort of horsepower do you reckon this baby should be putting out?
Anywhere near 180rwkw?? :confused:
https://www.sau.com.au/forums/topic/6067-how-much-horsepower/
I think 160rwkw +
https://www.sau.com.au/forums/topic/6067-how-much-horsepower/#findComment-91545
hehehe did u like it?
Sorry the T3 looks small doesnt it. But I use that turbo only against larger turbos....
I got mine against a t2 as well looks pretty pityful
You will be happy with a T3 They have slightly bigger ex housings than the rb25s and much bigger wheels so top end will be great.
https://www.sau.com.au/forums/topic/6067-how-much-horsepower/#findComment-92305
heheh i love it!
how much did that "little" beauty set you back, if you dont mind me asking?
https://www.sau.com.au/forums/topic/6067-how-much-horsepower/#findComment-92475
Its not as big as u think!
Ok well diced the highflowed T28 Comp housing and GT30 wheel and replaced it with a bell mouthed Aireasearch T04b housing and wheel and matched it up with the standard T3 exhaust housing but has a T4 vtrim exhaust wheel crammed in.
This time we diced the normal hiflowed ex wheel and put a shallower one on to get a bit more spool back :D
Before It had full spool on the RB25 by 3500 and now im hoping inbetween 3200 and 3500 but still produce the same amount of horeses but a slight chop in High end grunt.
Good quality bearings and apparently warranty no problem with high boost applications if need be
Not Cheap tho ud be looking at about $1800 mine was a bit cheaper because we found the T4 wheel, and no machining needed to be done because the turbo had already been hiflowed.
https://www.sau.com.au/forums/topic/6067-how-much-horsepower/#findComment-92686
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
