Hey i'm in the process of importing an 89' R32 Four Door GTS-T Skyline and while I think i'm pretty prepared for getting it on the road and running, I haven't the slightest clue about what needs to be done to the vehicle to pass it over the pits. I've been told that the car 'apparently' needs to have have side intrusion bars fitted, child restrait points and a couple of other things I can't remember to be done. I've emailed a couple of places about what needs to be done but there very inconsistant with there replying.
So has anyone recently gone through the process of getting an import registered or more specifically the GTS-T R32 and could tell me what possibly needs to be done to pass it through pits. Also I've never been through the pits before. Apparently it's a pretty evil place to go to. :)
https://www.sau.com.au/forums/topic/60680-compliancing-for-imports/
ive heard welshpool are pretty good...
As far as the bars go... i dunno... i know that u needa change all ure seat belts over to aus standard ones etc (so ive been told a few times)
but apart from that im not sure... you should probably goto a compliance workshop and discuss it further with them (one that has done a few imports before... someone here will know) and from that you should be right with whatever the pits rekon ... OTHERWISE... give the pits a call yourself and find out what needs to be done etc for it to be complianced..
then ya should be right...
let us know!!
good luck!
Took a car over recently. I put my GTR over in May and they hardly looked at the thing... easier than getting the modified Commodore over. Still had to get child restraints, unleaded fuel filler neck, etc...
When I put another car over just a couple of months ago, things have now changed. You now have to pick up a check list from the DOT that and engineer has to tick and sign off. You still have to do things like side intrusion bars, child restraints, flat drivers mirror but you also have to have an O2 test done on a dyno.
Seat belts themselves have to not only be in good condition but also have a particular approval number on them as well as brake lines. I had to replace all of these@ :)
It's all just rubbish red tape to stop people importing.
The car was a van for crying out loud!
The trick is to find a good engineer that is well respected by the pits - Welshpool are great. A bunch of no nonsense guys (good on 'em).
Once this was done it cruised over the pits.
Gawd that sucks, is there much stuff in compliancing that you can DIY? Or do you need to take it directly to an engineer and get them to comply it directly?
Do you have the name and/or business name of the engineer that you used to pass it over the pits? Cause if you would consider them good i may use them as well.
imports 101 are a compliance centre who are now importing. they are currently complying my GTR for me. they are based in welshpool on Radium st and the sign out front is Global Motorworks. give them a call and they can also email you a copy of what needs to be done to your car when he gives a price.
mark
Just to clear things up a bit (in case anyone wasnt sure) compliance and roadworthiness (or pits) are seperate issues. Compliancing is having the car modified to ADR (Aus. Design Rules) standards. The compliance workshop will do the mods, and the engineer will check them off a list. The car is has now been complied.
Now its time for the car to undergo a roadworthiness test, being taken over the pits. They dont really check compliance items here as you give them the engineers check off list anyway. If anything they check tyres for DOT or E markings.
Compliance:
Anti-intrusion bars fitted into every door
Drivers mirror replaced with flat glass
High-mount brake light fitted if not already (eg in the spoiler, rear windscreen)
Fuel filler restrictor
tyres to DOT or E standard
brake lines to ADR standard
Seatbelts - 89 r32's usually dont need to be changed (i'm pretty sure -correct if wrong)
numerous places can do this for you, or you can even do it yourself. Some places are
Autoworx, Phils Mechanical, A&B Autos, John St Autos (Not 100%) and more... I reccommend Autoworx in Wangara. Very good work and quick too.
check out the DIY Compliance thread, we've covered heaps more stuff there: DIY Compliance
Blacky
*edit*
GotBoost, you wont have to find an engineer yourself, its all taken care of for you as part of the compliance process by whichever workshop you choose.
Yeah went up and spoke to the guys at Autoworx in Wangara in my lunch break, mind you which is only 200m from my work :thumbsup: . Seemed like a bunch of real helpful guys, quoted me approximately $1400 for the fitment of 4 intrusion bars (aka 4 door car), high level brake light, child mounting points, fuel filler restrictor, side mirror (not sure if centre mirror needs to be replaced? Anyone?), an engineering certificate and some other stuff. And also obviously if i did a couple of things myself that price would go right down. Seems like a pretty decent price? Any comments?
I live about 2 mins from Autoworx, so I'm always dropping in to talk about imports, and getting mine complied - Paul (owner) is always ready for a chat and will even tell you what you can do yourself. $1400 sounds quite reasonable for a 4-door. My 2 door GTST was quoted at $1200, so you're on the money.
You may wanna confirm on the seatbelts if not already, as i think Paul said they dont have to be replaced on our ones... And no, the rearview mirror doesnt need replacing :thumbsup:
blacky
yes the white warrior is now a fully legal citizen as off last thursday! Its been a long time coming but worth it. Next is to the panel shop for a touch up but that can wait cause i'm broke :) Fuel pump is also suss cause its a little surgy when cold......hmmm
Nah the factory belts are fine, just make sure yours isn't missing the rear buckles like mine was! ha ha, stupid thing.....
Autoworx are tops, no bullshit, my car was in and out in 2 days. Very helpful guys. highly recommend them.... :kewl:
Ah good news man, how good is it when the car *finally* is ready to drive! If your'e up this way bring it round, would love to have a look at her.
howd u go at the pits btw? any hassles? i remember Paul from Autoworx was there when i was taking my last car over, he was getting a Prius licensed. I was in line chatting to him, and he was pointing out which inspectors to try and get and which ones to avoid - think thats what saved me as i got a good one. :)
anyone have autoworks phone number?
i need to get a unleaded fuel restrictor of them.
also, i hear i need a emmisions sticker for my car but the guys at nissian cant get one in english, only the jap ones. its the same deal with the tyre placard.
anyone know where i can get these stickers from?
thanx
steve
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
