HKS2540 pair suit GTR.
For sale again due to timewaster.
Turbos are in perfect condition with low k's (no more than 10-15k done), still in my car. I can guarentee you they are in perfect working order and will not need a rebuild.
Rated at 350ps (350hp ea) but as HKS always do rate their turbos at about 10% less than what they are capable of in a ideal situation so more around 385ps.
Im in Brisbane but can COD australia wide as long as your willing to lay down a small deposit.
$3400 delivered to your door australia wide.
Brett.
([email protected]) 0413 382 678
https://www.sau.com.au/forums/topic/60719-fs-hks-2540-pair/
probably a manifold that can house 2 turbos instead of one :rofl:
serious answer: these turbos are t25 flange, you need a T3, im sure you could get the pattern changed to suit your car but im not seperating them anyway, so if you could find someone else who wanted to buy one then you can take them.
or you can take them both and sell the other yourself, they usually sell for around $2000 ea. dont think it would take much to get the pattern changed on it but im just guessing, ask a mechanic if your interested.
https://www.sau.com.au/forums/topic/60719-fs-hks-2540-pair/#findComment-1166664
  • 3 weeks later...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
