r33 stock cooler without pipe that goes to turbo= $40
r33 s1 rear spoiler, burgandy, good condition, all leds work=$70
r33 stock springs,good condition, removed due to lowering= $50
r33 front blinkers off s1 front bar= SOLD
r33 stock air box and snorkel, good condition= $60
r33 series 1 front bar, cut up for front mount= free to good home, or 20 bucks donated to sau
i also have some stock s13 parts-
stock front springs= $20
stock silvia rear spoiler in pearl white, no leds= $20
email [email protected] for pics in reply if needed :)
https://www.sau.com.au/forums/topic/60759-r33-stock-parts/
yup...sorry i was away jsut got back yesterday. i got the pics but still need a mobile number. PM it if u want. also have u found out if the crack leaks yet? and is it noticible?
cheers, Mark
https://www.sau.com.au/forums/topic/60759-r33-stock-parts/#findComment-1165424
  • 4 months later...
