can someone please explain the KPI angle? i believe it stands for King Pin Inclination but that is all i know!
ahh well while we are swapping half informed opinions here is mine.
On a car with properly designed double wishbone suspension the KPI should be straight, that is the point of such a complex suspension design. The issue is with cars with a strut suspension like a S13 or R31
/end uninformed opinion
I've got s13 suspension if that makes any difference to any of the above advice/conversation (as in the whole thread).
yeap hes correct, the castor rod goes from the lower control arm to its mount further forward, shortening it will move the wheel forward for more castor
Except in cars like the 240 / 260Z, where the castor rods go backwards, so you need to lengthen it to dial in more castor.
For Greg, just reading up on KPI in Alan Staniforth's "Competition Car Suspension".
"...the original parts, which took the form of a piece of round bar, some 4 or 5 inches long and 1/2 - 3/4 inch diameter, gripped by heat or some sort of cotter in each end of a beam axle. The hub was given 2 bronze bushes on which it pivoted around the pin to give steering movement to the front wheels....
...the angle of the pin was so arranged that a line drawn through it intersected the centre line of the tyre on the ground.
The KPI is measured in relation to the centre vertical plane of the car, ie angling from middle to outside (as distinct from rear to front). You could consider the inclination of a strut to be equivalent (from top mount outwards towards the wheel), in that a line drawn down the axis of the strut should strike the ground at the centre point of the tyre.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
