Hey all,
A mate of mine and i were discussing the other day, Nitrous oxide.
He was telling me that you can run a 50 shot of nitrous and it can be beneficial to ure engine (as it cools down the pistons a bit aswell as the rest), rather than destroy it.
Im pondering possibly doing this to my own car... but would like some opinions first. Has anyone here got a nitrous setup in their car? running stock internals etc? Does anyone know roughly how much it would cost to get installed?
All info/opinions appreciated :(
https://www.sau.com.au/forums/topic/60796-nitrous/
  • Replies 52
Hey, coulda told you this before but I think I forgot to. Seen a stock Ti R31 running 50 shots down the drags with complete stock internals. He claims to have done 54 passes at that point with it and it didn't miss a beat. Got some nice low 14s which is good considering there normally people trying to pull a high 15 in stock form!
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151585
NOS is the "SHIT"! :)
I run an 80hp wet shot & the HIT is better than Viagra!
When set up propperly is is a safe & effective hp gain , tho getting it right can be an absolute BIATCH..... as those who were present at my first effort will testify.
As a result of this.....only a WET shot is worth doing (wet shot is where the correct ammount of fuel is injected with the nos).
I use Geogre at ADRENALINE for all Nos related stuff.... he's seen it all.
Go the Gas :burnout:
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151729
good to hear rep003,
so how much for somthing like this? do you still find it to be safe? I have always wanted to put it on but everyone always seems to say oh but this can go wrong and that can go wrong.
Plus not too mention the pic i saw recently were the whole engine blew up of the drag car when the lines caught fire! the whole bonnet flew off!!
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151789
MirKz, i was once into nos as i through it was cheap hp, if you look at the nos website they have different setup for different power lvls, i belived anything over 300hp they requirment you run forged internals.
i belived rev210, uses it in his car, and i think it was something like 100shot and he had good results also
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151915
croyden GTR did the same thing, only with his, when he reved and started a burnout, nos thought he was racing, so it put a shot in and had no where to go but up, and lets just saw, the bonnet only just stayed on.
https://www.sau.com.au/forums/topic/60796-nitrous/#findComment-1151980
Guest
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
