  • Replies 51
I *can't believe* no ones mentioned Bee-R B5 Sports Wheels:
Nice. They look like a cross between the Nismo LM GT4's and TE37's.
2GU, I love the AME's. Have done so every since they came onto the market. And especially after I saw a burgundy R32 GTR years ago with a set on it that was lowered (almost as much as yours :wassup:) with SYNRGY plates on it. He later sold them and put R34 GTR wheels on it. They are nice, especially on a Gunmetal R32, but I can't seem to justify the $3K+ price tag for a set of used stock wheels.
I don't like replica wheels, they just don't seem to look as good as the real thing. Much like gts-t's with GTR body kits and badges :):D:D :cheers:
I don't like replica wheels, they just don't seem to look as good as the real thing. Much like gts-t's with GTR body kits and badges ;):D:D :cheers:
yea i know the car ive seen it before its gorgeous :rofl:
they are a genuine three peice japanese wheel thats why they are so expensive, when they were available the price was pretty much the same as most jap wheels going around now.
i agree 100% thats the copies look like shit
they are nothing compared to the originals
yes mine are genuine 3 peice 20" AME modelart wheels
they are 8 inch wide but i wana get a new dish made wider on the rear im gonna try and fit 9"
i got em second hand but i have been told that brand new they were worth about 8K
I was listening to the radio the other morning and heard about a Nissan Skyline that has a pulsar motor and the number plates Next Time?
I'm a total whore for anything race style 5-spoke, and most sweet six-spokes. I'm buying these, coz they're under $1000 in Japan (where I'm getting them from):
A-Tech "FinalSpeed cast" - Not a bad ripoff of the Gramlights methinks.
I Also considered the Wedsports SA-90, and the Voltec Racing RGR
600x450-2005011700124-7.jpgwheelmania-img500x500-1096477734rgr1780%2030_5-114_tibr.jpg
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
