i have a couple of things im getting rid of
rockford fosgate monoblock 900w amp - 350
7inch indash (not motorised) TFT screen - 400
two 15inch pheonix gold subs & boxes - 300
clarion cd/mp3/wma player (model is the 546 series) - 250
boston 6 inch splits & 6 inch 2ways - 250 (for both sets)
civic EG 4door - LED skyline design tail lights, angel eye projector headlights
and clear front corner lamps - $500 (for the lot!)
r34 trust mushroom air filter (yellow) - $100
contact john - 0401449737
https://www.sau.com.au/forums/topic/60850-miscellaneous-4-sale-syd-only/
