painting rocker covers
mitchy_
 Share
just after a bit of advice with painting the rocker covers on my RB25....
i know i need high temp. paint, but any specific brand/type you guys recommend? or any other hints and tips?
thanks :cheers:
well, first off, you know all about removing and putting the cover back on? Otherwise, really any high temp engine paint will do.
well.. from what i saw yesterday, it comes off pretty easy.. nothings going to fly out/break/etc when i take them off?
2 pac paint and lots of prep work but be carefull as 2 pac is carcinogenic.
its pretty much prepped, i spent all yesterday cleaning all the crap off them, will give it a good final clean once i take them off...
im guessing they need to be primed too?
i used some high temp acrilic you get from supercheap. it looked good, but i found out if you put it in the oven for a little while it lasts longer.
I also gave it a couple of clear coats too, but unfortunetly didnt bake it.
heres a pic of the laser, i might get the gtr proffessionally done.
steve
and its expensive too
This is the job I did on a Proton Rocker Cover... harlequin purple to green..
Spray cans... $80 for the paint..
some prepsol... bit of sandpaper...
geez it was tempting to polish the crap out of it after it was cleaned and prepped.
that looks pretty damn nice..
id love a silver/blue harlequin paint :D
Mines going yellow this week (along with block, plenum, timing belt cover and coil pack cover) - will post up pics when finished.
Using high temp engine paint from SuperCheap (get the lot for less baby!!!!).
Appreciate any additional tips for stripping original paint :D
Appreciate any additional tips for stripping original paint  :)
thats what i was going to do too kel, cept blue :D
give it a few coats of high temp clear spray.
steve
did a little bit of a test run tonight.. only did one coat, but it looks alright :P
(the 'real' colour is actually between the 2 blues that it appears in the photos, and looks much nicer in real life)
  • 6 months later...
Don’t mean to bump this thread, but anyone who is using 2 Pac paint to paint rocker covers, be advised as stated above it is carcinogenic. You need a Full Face respirator, as the carcinogenic are absorbed even through the eyes. I use to work full time for a safety crowd and even there we always recommended for liability, an air line hooker system. But hey a complete over kill for a one rocket cover. But keep it to an open well vented area.
 Share
    • Anything for a 2003-2005 G35 will fit an M35. Just be mindful about clearance if you're running a plenum spacer or runner spacer.
    • You know how I know I'm getting old? Because I feel this quote jells with me and SAU Forums, ha ha ha. I've gotten lost a few times as I had muscle memory to scroll to where I wanted on my phone and just click, now I'm lost... Ha ha ha     "I used to be with ‘it’, but then they changed what ‘it’ was. Now what I’m with isn’t ‘it’ anymore and what’s ‘it’ seems weird and scary."
    • You don't lose spark if your battery isolator isn't wired correctly and the ECU still has power from the alternator.   Car has an epic wiring problem. Sounds like power connected really really badly in places. Possibly a power pin on a ground pin for the ECU, and constant power in locations that should be switched ignition.   It needs someone good at diagnosing electrical, a good multimeter, and someone with the wiring diagrams to match the engine loom that has been put into the car, and wiring diagrams for the body side of things from the car.
    • Hi folks, what options exist for PNM35 or what models share the same dimensions and fitment for the front top of tower strut brace. I have seen a few options pop up through Google, the Ultra Racing Australia for one. I have seen some eBay ones that claim they fit C34 and M35 but can't find details if to work out if its true. Also found Taiko / TEMA4x4 claim the one type fits: - Nissan Stagea (2-nd gen; M35) 2001 - 2007, - Nissan Skyline (V35, HV35, NV35, V35, PV35) 2001 - 2007 - Infiniti G35, G35X (3-rd gen; V35) 2002 - 2006 But not sure how true that is. Anyone fitted one or know of someone using one and can confirm what does fit?
    • I got the full kit.   The compressor as above is much smaller and lighter.  Also quieter. Bracket is visually mint and much lighter. The dryer and heat exchanger(rad) are one unit. Also smaller and lighter.  Much more room for an oil cooler. The fan I got was a bit Meh and I might change it.   And above all else it is more efficient, tested a good 3-4 degree's cooler than the old system, which is a lot. Disclaimer though - It wasn't a back to back test given different days. It really does feel colder though(always).  And this example is in my car with that crusty looking old compressor, not new vs new
