Hey, im having a problem with my RB20DET (R32 gtst) When i rev the car to about 4000rpm+ sometimes I get a popping noise from the exhaust. It doesnt seem to loose power but as you can imagine i am off the gas as soon as it happens!
Anyone got any ideas on what it could be? I was thinking faulty coil packs or Sparkplugs!
I just read another thread....
Another guy had same problem and faulty coil pack for him.....but also check about fuel richness, could also be a contributing factor.....not sure though....hopefully someone with more knowledge will post soon....:cheers:
Check all of the above, plug, coils etc
a mate of mine also had a similar problem, it would only occur now and then, it turned out to be the crank angle sensor had come a little loose at some stage and it had chewed all the gearing of the exhaust cam - result - new exhaust cam and CAS had to go in, and problem fixed
Check to see if the CAS is tight, or even pull it off and have a look at the splined gear inside, if its all chewed up, chances are thats your problem
Chris
had exact same problem with mine yesterday...... under load and at about 4000 rpm and REALLY badly at 5000rpm it would be popping and braking down on power delivery..... got it home after blowing smoke and dropping flames..hehe ...... changed the plugs and now she;s good as gold now.
Matt
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
