Darn, now I definately know im missing the lower lip off my front bar as I have the same design as the red car.
JK
I think its an aftermarket (or factory option at least) lip. Because that IS my front bar (just not cause its not my car) But my lip is now up in the roof of the patio due to a mistake. And yeah, my car doesnt look silly without it there.
https://www.sau.com.au/forums/topic/60911-cef-stock-bar/#findComment-1154068
