if i had $25k+ i would get that....
work on it at my bro in laws panel shop.... mmmmmmm flares lol
2k to finish off the body work... a nice 5k paint job... maybe a nice sparkley/glitter red or something :)
need more pics of inside, out and under body like i had for mine... wonder if they have any
