  • Replies 113
OK have set a tentative date: 22/1/05 at 9:30 AM
thats not this sat but the next i think thats plenty o time to get the ceff ready.
The venue is Procar Pty Ltd
they are at:
7 Middleton Rd, DEE WHY, NSW, 2099
Phone: 9981 5099
Mobile: 0417 236 411
Fax: 9972 1947
What you get:
A. 1 test run to calibrate the machine, check a/f ratios ect
B. 3 Power runs in shootout mode in 4th gear
C. printout of you cars results (dyno graph)
D. wow factor when you know how powerful your ceff is.
If we can get 10 cars we are set.
Cost will be $50 each
The guy there is very helpful has a basic but good workshop. I have used his dyno sevral times before. he has a massive fan for intercoolers and all the stuff we need
Also it would bee cool to have a bbq somewhere afterwards for lunch any ideas?
Hmm I'd like to have one power run then remove my exhaust and swap with someone for a brand name air filter and do another power run.
Wonder if it will make ANY difference.
I will PM you.
Procar.. middleton road... hmm that's right near Cromer Exhaust Centre - Good oh!
ja i will come - if anyones rolling past chatswood to use the waringah / pittwater road way (pretty much the most direct route i know of if your on the north side) to get there gimme a message and we can do a morning cruise to dee why together... ceffie, cc and so on?
we can suss out my boost levels questions hopefully.
Lemme know when you're doin that I'll join up as you pass me in on Warringah Road (since I live on the way to Cromer if you're goin down Warringah.)
PS Pittwater road isn't the most direct route - I can't remember what it's called by there's a road that's way closer I can take you on if you wanna meet up on the way on Warringah (or I can cruise to Chaty thats cool too).
As for food -
1- bbq seems unfortunately unlikely.
2- brookvale pino's pizza takeaway - maybe a couple of us could do a run down to grab the pizzas and come back for the other lads ? (I'm assuming 10 cars might take longer by which time we'll be hungry)
3- somewhere we all cruise to such as manly and grab a bite (little pizza place opposite the wharf bar?)
4- something non pizza.. ie run up pittwater road to avalon or something and get fish n chups?
5- drive back to chatswood and crash the yum cha place (downside is our cars will be in the car park)
I like number 3 but I can see getting 10 spots near there might be a bit hard.
Any other suggestions?
too_much_boost - I'm hoping to crack 200 and on the curve hopefully get about 2000-3000rpm at over 180.
I hope that's not being overly optimistic - and if it is I hope I get it :)
Thing is UAS dyno said top run was peaking at 198.4 or something and since then I've put on the equal length exhaust manifold but put on a resonator. It'll be interesting to see what happens.
last run for my car put out 160kw
since then i have added rb25 turbo, FMIC, new dump pipe and cleaned up the tune so i am hoping for around 180kw but i have also added a cat that wasnt there before
but i dont really care too much about the numbers
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
