No I haven't bought mine yet, however if I lived in the UK and had an exceptional amount of money, the new EVOVIII MR FQ400 would be top of my list.
0-100 in 3.5
Article Here-> http://driving.timesonline.co.uk/article/0...1406902,00.html
Some quotes
"The brakes, which are to a bespoke specification, are so powerful I half expected them to trigger the airbags"
"I have it direct from Mitsubishi that 400 refers roughly to its power output and FQ to the words that come out your mouth the first time you sample it. And, yes, the Q is “quick”."
10 points to whoever works out the F in FQ first :)
It's also in the latest SPEED magazine I beleive.
https://www.sau.com.au/forums/topic/60923-the-evo-has-landed/
There is a bloke at work who wouldnt shut up about it. He s totally in love with it. He reckons he read an article which said that they took it for a spin on the track and it won against the Zonda. With that horrible torque curve i doubt it is worth anything on the track. Unless its got antilag its only good for drags.
Depends on your ability to keep revs up IMHO. Evo's have a relativley close ratio box, so a bit of the ol' heel/toe and even shifting into 1st if neccessary (OMG! People do that! People like me :P ) and you could probably do alright.
On the subject of being in love with it. I have already have two wet dreams about it. The best one involved strapping into some gravel and hitting the gravel mode button. The sheets will never be the same again.....
:bananaman:
Depends on your ability to keep revs up IMHO...
Against a Zonda on tarmac? No way. It just wouldnt have the response needed to corner.
Read this:
http://www.lancerregister.com/showthread.p...15&pagenumber=6
Quite interesting seeing all the Evo boys creaming over the 400.
If you keep the revs up in it, its a very quick car point to point. I have seen video of it whooping a Lamborghini Murciellago around a track, and before anyone crys foul about inexperianced drivers, the Lamborghini was being driven by a professional European touring car driver.
It is a very very very quick car point to point through corners, you just need the brains and balls to know how to drive it properly :D
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
