Apexi turbo kit fs
hi guys i'm sellin my apexi RX6 turbo kit off my rb25. this kit is awsome made 398rwhp on 1.2bar sellin because upgrading to t88 :) kit comes with following:
-Apexi RX6 full ball bearing racing turbo(based on f1 turbo) 550hp rating
-Apexi cast manifold multi fit(will fit rb20,25,26) :)
-Apexi huge external gate(think it's 50mm??) with stainless screamer pipe
-Apexi stainless steel dump with 3 1/2 inch down pipe(heat treated)
-Apexi polished chrome heat sheild(looks awsome)
- comes with oil lines in and out.
this kit has only done 10-15,000k's since new!!!! and is all in A1 condition
on my r33 pulled dam hard and torquey as anything, could even be used for a drift setup :P
price is dirt cheap at $2500aud as have to get rid of her for new setup
Photos? Are we sure its the later series BB RX6 and not the old plain bearing turbo. The later kits usually have tubular manifolds, adn the older its cast manifolds...is my understanding correct. Dont know much about these kits only going on what i have seen:)
If it is a later model BB turbo, very , very interested...
will post up some pics later on soz have to find some. from what i under stand is that all the RX6 turbo's are ball bearing. as in all apexi turbo's with RX6 stamped on there cores are ball bearing. i think u are talking about the old school Rh9 series or something like the old school apexi gear real old school hehehehe. so yer it's 100% ball bearing.
Ok...so next question...:)
Looking at the core it appears to be only oil cooled, again im not sure so just askign the question, I "thought" the later model BB Apexi turbos (IHI) were also water cooled????
Where abouts are you located. Im in Adelaide with work at the moment, but usually in Melbourne. Keen to have a look
thanks for ya post macca, on my rb25 turbo starting getting boost at 4k pulled dam hard by 4500 and max boost at 4800 or so. but with cams this would be heaps less laggy as my rb25 was pretty stock(internal wise)
-sorry canadian skyline 2k is crazy talk i want/need 2500 soz which is a cheap price!!!
hi guys i'm sellin my apexi RX6 turbo kit off my rb25. this kit is awsome made 398rwhp on 1.2bar sellin because upgrading to t88 :D kit comes with following:
-Apexi cast manifold multi fit(will fit rb20,25,26) :(
on my r33 pulled dam hard and torquey as anything, could even be used for a drift setup :D
Hey, interested.
On the Goldcoast
Is this turbo still for sale?
Email me: [email protected]
  • 4 weeks later...
 Share
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
