i have a water temp readout on my hand controller and the temperature ofcourse varies.
If i am moving the temperature can be as low as 74deg
(i have quite a substancial aftermarket radiator)
85degrees is fine, i wouldnt be concerned about that at all.
When i am stopped in traffic on a hot day (25deg+), the temperature will rise up to around 102deg.
I would start stressing if my water temp got to around 120degrees... but i'd never let it actually reach that heh.
Concerning Oil Temps... i am unsure, i dont have a oil temp gauge and i havent looked into correct operating temperatures. But good move buying these gauges, they give you useful knowledge - i've had my car up to around 109degrees in water temp, and the stock gauge doesnt even move and just reads normal.
it depends where the sensor is....
my friends R33 has had 2 different ECUs in it (both aftermarket)...
the operating temperature on the first ecu read quite low... in the mid 70s....
on the current ecu, it reads higher operating temperature being in the mid to low 80s.
The ecu was the only thing changed no changing of coolants or radiators... so i think its mainly where the sensor is placed or something.
But yeah... i think its just important to know where the danger levels are and to steer clear of them.
If my car gets up to 100deg in traffic on a hot day... i will put the heater on, its a bit of discomfort to me, but i dont mind, i'd rather that than damage something. Wacking the heater on will usually bring it down to 94-96deg... this will vary ofcourse depending on the car and the radiators and the fans used.
In some cars i've used, switching on the aircon can lower temperatures as well if it gets too hot.
I think i read somewhere that in the R32s (assuming it would be the same as the R33s) when it reaches a certain temperature it will switch the AirCon fan on automatically for increased airflow.
As the water temp question has been answered, ill add my thoughts on oil temps as i have an aftermarket oil temp gauge
My oil temps stay between 80-90degress on daily/normal driving...
Quickly gets to 102 on hard driving, mainly on high speed on/off boost, mountain runs.
I found that it didnt move much above 102 during this prolong hard driving (45+mins)
Respectively, the water temps were stable at around 90-100degrees
True, my AUX (aircon fan) switches on above 92degrees and quickly drops the water temps to nominal temps
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
