Hi,
Does anyone know the correct procedure for cleaning an HKS pod filter, the yellow one that looks like a big mushroom?
I have cleaned it out using the solvent part of the K&N kit, but I am wondering if it requires an oiling??? I don't think it does but if anyone knows please let me know.
Thanks in advance.
Sam.
https://www.sau.com.au/forums/topic/60959-cleaning-hks-filter/
Hey BlueTwo....
Ive also got a HKS pod, except its got the green element..
These should not be cleaned - but replaced.
They come pre-oiled, and dont take too well to washing/cleaning.
Depending on driving conditions, i would change it every 15/20k...
Cost is about $70 from autobarn...
:D
Hey Gizmo,
Do you know if there is any difference between the green and the yellow one? The yellow one looks like a big sponge, with what seems to be a good capacity airflow through the matrix of fibres, quite a bit different from my panel K&N with it's cotton insert.
...The flow of the HKS is one of the best when compared to others..
However, regarding pods as well as any other filter - more/better air flow usually means less protection filtering elements.....as attested to the pod noise !!
So - conversely, the HKS pod filter also isnt one of the best in regards to protection. Its your choice what you are after.
Every 20k i also check the AFM and tubing for any particles - so far it is ok, but you need to change it at least every 20k to ensure you dont get any nasty surprises..
colour difference is mainly for show - however, some colours only come in some sizes...it all depends on the size of your pod..
http://www.hksusa.com/products/?id=787
:D
