Here are some Pics of my great and glorious sub box
it's not 100% because the stupid jigsaw broke this afternoon. i'd hoped to have it in one piece by now
Also these are taken with my phone, my camera is in the er... shop.
It's setup for 2 x 10" plus my 400mm long Amp, which is why it's so long. the subs are within about 5mm of touching the side, which are flush against the suspension towers in the back. there is about 20mm clearance on either side of the amp from the subs. once i get some carpet to match the boot, it will look a lot better, trust me :rofl:
  • Replies 46
Well it's basically finished now. All i have to do is cover the mdf with carpet of some sort, and figure out why the stupid thing cuts out at high volume.
also, for some reason my head unit now no longer functions and i have to use the remote all the time.
anyways, tell me what you think
It doesn't sound, i had to send my head unit off to be inspected to see if they'll honour the waranty, so about 2 weeks until i have my head unit back. before i'd sent it i thought i'd fixed it up, but then it gradually got worse until it was back to where it was, which ot me sounds like either a heat problem or something gets looser as the car vibrates.
Yeah i'll get it for you tomorrow if that's alright. there are 7 pieces of MDF in all. Mine was a bit of a dodgy fit, but i'll get dimensions that will fit. A 'Prototype' as such
Get my stereo stuff installed in a few days!... wasnt gonna spend too much originally - but got a price too good to turn down... so if anyone else has been thinking about DVD and roofmount screen (for kids) then I'll post the deal I got...
Based on the pack in the summer Alpine catalogue... with the DVD head unit, 2 x IR headphones and 7 inch drop down TFT for $1999 reduced from $2799...
Told em I only had $2000 max including fitting and needed normal tuner head unit too, so the guy rang the store owner - who just happened to be sitting down with Apline distributor looking over the new Alpine stuff hitting stores soon... including an 8" screen replacing the discontinued 7"...
So he agreed to do the Pack plus a RRP $369 head unit ALL fitted for $2000!
But it got better - I said I really wanted MP3 compatability in the headunit - and he said the lowest price was for the IPOD atachable unit reduced from $699 to $499... BUT then he remembered they had them further discounted that week for $299!!
So the new price he agreed to all up including fitting is $2015, for:
- Head unit CDA-9826 (Ipod system)
- DVD player DVA-5210E
- Overhead drop-down screen (not sure on part # but its the new 8" version of the TMX-R700)
- 2 x IR headphones
RRP of $3700 + fitting (~$350) all for $2015 fitted :D :aroused:
Hi guys, fianlly got around to fitting up the stereo gear the night before the 1200 k trip. It has a Nakamichi head unit, a Soundstream 400 watt 4 channel amp and 2 pairs of MB Quart 6.5" co axials, one in each door. The amp is mounted under the driver seat at the moment, but I might move it later on.
Big improvement over standard, I ran out of time to fit the front tweaters in the A pillars. I removed the standard tweaters but was slowed down by not finding any signal at the standard wiring. This weekend I will run around with he multimeter and find the other end of them.
I now have a spare din hole, gauges maybe? The Greddy boost gauge is 60 mm, so it's too big though. So is the EGT gauge. More thinking needed and some suggestions might help????????
Sounds like a nice setup there SK. Nakamichi desks are nice and clean. And you can't go past MB Quart's. You gunna put 4 15 inch subs in the back :(
If I had a spare DIN space I'd go straight for the 3 x 52mm gauge mounts you can get. They look pretty good (look stockish) and the little thieving ba$tards can't do a smash and grab ;)
I mounted 3 x 52mm gauges in the R33 like that and I was really happy how it turned out.
J
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
