  • Replies 305
Its been a while since i been on a cruise, So now I have some street tyres on the car again I'll Be there. Plus I need to have at least one cruis b4 the girl runs outa rego and becomes a track car only for the next few months.
yay matt!!! you're coming along? maddd!!!! good to see you back in syd!!! :) when did you get back?!?!?!?!
Ash - not sure about re-entry... but it really depends on how people want to get home... we might talk old pac while others just hit the f3... dunno!!! there are a few peeps that need to be back in syd by 4 though, so you'll still get a cruise on the way back :)
