  • Replies 305
0288 were you going as fast as we were going in the s2000's on the S2k Putty Road run awhile back?
We weren't going that fast... I was right on their ass the whole way in the Bimmer and I had sizeable safety margin left in the handling that I didn't need to push too hard...
So it would have been a piece of cake for the S2000 and Skylines...
