11 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi All,
Is motorvation on this weekend? i think it is??
If so was wondering for those of you who are interested if you would like to meet up on sunday at citywest at 11am for a nice cruise down the freeway so we arive there about 12.
what better way to gatecrash TREVATION than with a whole bunch of skylines rockin up... HELL YEAH!! MWAHAahhaahah!
hands up those who maybe interested... maybe if ican get a poll goin
You would want to go earlier, Sunday is a short day, (10-5) If you get there at 12 the time goes real quick, Saturday is the day to go you're not working/busy etc, goes 10am-10pm, with more cars competing in the burnouts, driving events etc.
I agree should get there a little earlier I normally get there around 11. The first super cruise starts at 12 and i don't want to miss that :P Here is the time table for anyone thats interested
10:00am Spectator Entrance Opens
10:00am Driving Events Session 4 (Slalom 4, Go Whoa 4)
10:00am Judging Scrutineering Area (Final 12 noon)
10:00am SoundzExplosive - Soundoff
12:00noon Supercruise 3r led by Gary Myers/Milan Dokic
12:25pm Supercruise 3y led by Gary Myers/Milan Dokic
1:00pm Driving Events Session 5 (Slalom 5, Go Whoa 5)
2:30pm Burnout Competition Final
3:55pm Myers/Milan Dokic Burnout Demonstration
4:30pm Formula Tech Dyno Trophy Presentation (dyno area)
4:30pm SoundzExplosive Soundoff Trophy Presentation (Sound off area)
5:00pm Close
5:00pm Trophy Presentation (Gold Seating Area)
Yeah that would be fine,
am thinking of changing times then for yas and perhaps meeting at ten.
I do have a few things to do that morning thats all but should be able to make it.
I have been to the past 4 motorvations and have had my car in 2 of them. nothing good starts happening till 12.... but if we can all find a time thats suitable for us then we will do it. as excited as we all get it is crap until 12. the competitors stay overnight in tents and stay up till 3am.............
I killed my GSR Turbo Lancer at motorvation about 2 years ago, was in the car audio compitition aswell..man Im missing the boost..me and my mate might tag along in his nissan pulsar SSS if its kool?
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
