LoL hahahahahah
what car u in [ryan] ??? next time beep/scream/flash (headlights aswell) and ill stop...... u take some pretty schmick pics....
i always see a red/black/silver skyline on queen street....
we all go the same time to pick people up :D
how did u know i was wanking...... i though i did a good job of hiding it and i didnt get any on the dashboard this time....
  Quote
Originally posted by UR2EZ
na was thinking bout j00 mumma eug :D
hahahaha na i dont know what i was thinking.... prob was just quoting what i hear from minh every mon,tues,wed,thurs,fri,sat nightsssssss
not sunday or else his g/f would get toooo suspicious (mine too)
lies i tell you. Absolute lies and there is no strong evidence to even suggest that..............
wanna have sex? :)
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
