after getting my new front bar, im looking to get a 600x300x75 FMIC to fill out the intake nicely, and have a friend interested in my current 450x300x75 ARC intercooler...
so im wondering what it would be worth? (IC only, few damaged fins small dent in bottom causing a few fins to be bent, but nothing major)
cheers
https://www.sau.com.au/forums/topic/61053-450x300x75-arc-fmic/
would u be interested in a swap for a hybrid 600x300x75 maybe ?
not defiente yet but the hybrid is a bit big for my s15 so i might be looking for something smaller
oo, yeah i would be interested, let me know :P
    • E10, by very definition, has 10% E in it.
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
