i guess it depends on what you want to do in the long run, keep stock turbo or upgrade and so forth from my understanding bigger isnt always better. i have a small trust fmic and it works great with the stock turbo, but if your upgrading everything then plan ahead and get a larger size cooler. it seems most japs wif low budgets just get an oil cooler and keep the stock cooler on their ceffs.
I was in the same boat a few months back.
I ended up getting a 600 x 250 x 70 mm intercooler from a guy on ebay brand new for $330 its an interesting cooler and the insides look like (///////)
its not a tube but an extrusion with fins on the outside.
it performs very well but it was a bitch to fit behind the stock bar and i made all the pipes myself. i wouldnt reccomend this take it and get it fittred professionaly because it took me a whole day to fit it and lots of trips all over the place to get all the bits i needed.
all up if i had taken it somewhere it would have cost me $660.
it is the same length as the gtr cooler but 50mm shorter as i wanted it to fit without being to low.
I have been happy with it and would not reccomend going a bigger sidemount.
here is a dodgy diagram took me a while to draw hehe
there are SEVEN!!!!!! 90 deg bends. and one piece 600mm long i bought it all from liverpool exhaust for $90
then i bought silicone hose and you need a
LOT
take my advice and get your bends lipped unless you want to blow off hoses every time you hit boost.
buy good hose clamps.
its a super tight fit
I have a VG30 turbo and bigger fuel pump going in hopefully in the next few weeks and just looking at working around those for now.
cool, i wanted to go the vg30 as well, what have you been quoted on the power output, i heard they are a very good responsive turbo.
sorry to change topic.
dont put the vg30 on if you still want to keep your excellent response.
I have had t25, t28, t3/4 hybrid, vg30
t25: excellent response and comes on fuul boost fast but not much power
t28: good/very good response good useable power throughtout rev range
t3/4 hybrid. lag city piece of shit
vg30 excellent power but too much lag for the rb20.
get a rb25 turb or save for an hks 2530
Yea i have heard thats its a bit laggy but on the cheap (for me) as my turbo is a bit stuffed and need it replaced soon its the only option ..... . for now
I have talk to a few poeple and the VG30 was a good upgrade for them but I will find out soon enough
my mate put the MA70 FMIC on with inlets on the same side and used bugger all piping too was a great upgrade for him (silvia rb20)
still unsure what I would like or what I could afford to do. but it will sure make up my mind
I have an EVOIII cooler and 25/30 on my Cefi.
Its only pumping 1 bar through it, and is a fantastic intercooler on the cheap.
Myself and a friend with an SR TA Celica are both making over 200rwkw with these coolers no probs.
the ma 70 is an excellent cooler you should be able to pick up for 150. i know a few guys using these coolers on sr20s with good results.
if you can find a vg30bb get it or other wise a rb25 can be had for 350-400 with zero mods needed.
I have modded the housings with my rb25 turb and it spools up even slightly quicker than the rb20 but max power would be 210 215rwkw @14.7psi.
Also keep your eye open for bargins i have seen some excellent turbs going on ebay for around $500 :aroused:
The toyota cores look big, but have thin restrictive tubes and don't flow all that well compared to aftermarket units
The hybrid cores (or copies) would run rings around those toyota cores for flow, and can be had for $300-350 for a 600x300x76.
I don't understand why people use factory coolers as an upgrade anymore with new coolers being priced so cheap
Make sure if you buy a full kit with the piping, you get it for a RB25 R33. The R32 and Cefiro use basically the same piping, but they have a couple different one's that you don't really notice until after. In my experience, if you use piping made for a 32, the side where the stock intercooler goes never sit right, because the bends to the stock IC are at different angles. So basically, it'll always sit crooked. If you use R-33 piping, it sit's just right. That's how it is over here in japan, but it might be different over there.
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
