"Just Letting You Ppl Know, That For Now Id Be Very Weary Of Buying Anything At The Moment Off This Person. On Wed Of Last Week I Payed Him 250 Dollars For Some Parts And Was Going To Give Him The Other 100 Once The Goods Were Delivered. Was Expecting Goods To Be In At My Door On Friday And Since I Told Him That The Money Was In, He Hasnt Answered My Calls, Has Not Called Me When He Said He Would, Will Not Reply To Emails, Pm's Or Reply On Msn. Just A Word Of Caution."
Agree With BABS on this just spend 5 weeks for a turbo which was meant to take 3 days.Still dont have a turbo only got my money back 2 weeks late by constant hassling.
"hahahah u guys dont even care bout wat the above guy said......."
AGREED TOTALLY LISTEN TO PEOPLE WHEN THEY SAY THEY ARE GETTING RIPPED OFF.
"What did you buy babs? **** 250 is a low amount to steal off somebody...especially since I was about to ask him for goods worth over 10k...aiya...the net is so confusing at times"
Buddy he will try to rip off any amount.
You are on drugs if you give him 10k.
JUST A WORD OF WARNING FOR EVERYONE OUT THERE.
Always be weary when dealing with people over the Net. There are many dodgy fux0rs out there....
Lucky for me I live in Vic, so if/when I am looking for R34 parts I can simply go there in person :rofl:
Just in response to the negativity I initially found on this forum, I went to this guy's warehouse yesterday and he was very helpful and I bought off him an R32 GTR front bar. I wonder why others have had problems? Seems like a genuinely nice guy and I may even be getting my cars complianced there. Thanks all.
Closed.
Enough is enough.
GDTNO: Your conduct as a trader on this forum leaves a lot to be desired. Not only have you racked up multiple complaints, but you also fail to follow the rules of posting in this section.
Its clear that those whom you have shafted are taking these matters further, I hope for your sake you clear this issues up before you land yourself in hot water.
Guest
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
