could be mistaken for wanker tho :D
god ni you're quick... lol
as for the vinyl $100 WTF? the vinyl itself that size costs about $10, you're telling me they charge $90 to put a EPS design into a PC and to cut it up to that shape (ie press the cut button on the vinyl cutter). Its a simple 1 colour vinyl dude.
  • Replies 68
large red stripe is a roll of adhesive vinyl lol... $15 bucks per 5m roll.
That's it... I'm buying a vinyl cutter... at these prices I'll make a small fortune.
thats what u think lol
if only it was that easy... theres a bit more to it... and its actually 2 colours cause u have white and red. but if u think it will only cost u $10 to do it... by all means.
my mistake its 3 colours... 2 shades of red...
just do the sign... as for the stripe you can just get a roll of adhesive vinyl and use a pair of scissors to cut it out before n after the sign. this is backyard decals anyways, dosen't need to be precise.
Roy... if you wanna fund a large enough piece of vinyl then I'll use a surgical scalpel and a blown up printout to fashion you a decal. We can do it at Geoff's house when a game of rugby's on n make an afternoon of it.
put the big arse koala rip off of the uras monkey on it?
WTF ??!11!?
put a drift sticker on a Team Wang track car? Don't you like being able to breathe without the aid of a respirator?
My car may be  jap car but im a redneck Aussie:) No Jap Drift Stickers for my car...perhaps Sandman decals or 351GT stickers, maybe a shaker on the bonnet?
How about a Crow Cams or big mofo FOX sticker on your back window then? hehe
WTF ??!11!?
bah its only a few suspension and tyre changes away from being a drift car and vise versa. Do both I say!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
