My R32 GTR came in from Japan fitted with a carozzeria MEH-P9000CD head unit which work fine (needs a band expander, of course). The japanese owner had taken out the CD stacker from under the passenger seat, but the wiring is still all there. I basically only listen to CD's, so I'm wondering whether I can just plug in a pioneer cd stacker - although if anyone has a suitable carozzeria unit lying around.... :P
TIA
https://www.sau.com.au/forums/topic/61085-carozzeria-head-unit-pioneer-stacker/
i wonder if a carrozerria ipbus works with pioneer ipbus
yes they are the same product really. carrozerria is japanese pioneer domestic
i had a carrozerria deh990 with an ipbus socket and a cdrb20 ipbus from pioneer and it worked, the cdrb20 (haha no its not an rb20det) converts the ipbus to stocker rca in plugs. so in theory if you find a stakcer that is ipbus (i think like 95% of them would be) then it should be fine. i dont think they do many fm modulated stackers?
I think I've got a diagram of the pinouts somewhere if that helps any ?
Anything like that will help (my e-mail below). I've downloaded the manual for my HU from the Pioneer Japan website but it's all in Japanese of course :(, still there's enough pictures included for me to work out most things.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
