hey every1,
well im thinking about getting a FMIC and i just talked to my m8 who's an engineer and he said he will make the piping for me for free (i dont evan have to pay for the pipe) so what i need to know is does n e one have instructions on like where to bend n how for to bend down and what size pipe i need, and how much of it?!?!
n e help would be greatly appreciated!!!
- Greg
i have a VL berlina with a RB20 if that makes n e difference
https://www.sau.com.au/forums/topic/61091-free-intercooler-piping/
there is no easy answer. pipe shaping is dependant on the car, and the way you wanna run the pipes e.g. through the guard, over the radiator (if there is room). You have to work it out for yourself.
That is why companies can charge so much for them. It's not just the cost of the piping. It's the cost of working out how to make the pipes. Say for someone making $200 a day, they'd be better off just buying a premade one, because i'tll take you a day, and the money you'll save will be the same as the money you woulda made.
Intercooler piping should be cheap as anyway.
For a mates car I just bought some preformed 3 inch 90 deg mandrel bent ally pipe and a couple of straight sections. Then measured and cut it up and took it down to a local fabrication shop to be welded. Polished it on a buffing wheel, laquered it, fitted in under 2 hours and thats it. Looks just as professional as anything I have seen and after 6 months on 15psi it's still working (and looking) like the day we installed it.
So to answer the question, the best way to work out where things should go is get your pipe, start at the turbo side (or where you plan on starting your piping from) cut the pipe section, tape it in place (silver plumbers tape works really well), cut the next section and so on untill you get to the end of your pipe run. mark and number the sections then send them off to get welded.
The other option is doing a detailed CAD model of the front of the car, draw in the piping then export the parts to a 2D construction drawing. First option is prolly eaiser for a one off.
So I'd reccomend making your own piping, a hack saw, metal file, pipe vice (preferably), a bit of hand eye coordination and a scriber is all you really need.
Lot cheaper, just as professional and this way you can tell all your mates you have custom intercooler piping :P
My guess, definatly not thicker than 2 mm in stainless, the pipes are not structural and the pressures are not high, they will just weigh too much if thicker than 2mm, thats why I would use ally. You will not find it easy to get 2.5 - 3 inch stainless steel mandrel bent pipes (ally would be eaiser to find).
Actually Stainless mandrel bends are easy as to get :cheers:
Plenty of them around.
Are you referring to thickness or diameter of the piping?
Thickness as previously posted, no more than 2mm.
Diameter, depends on quite a few things, length of piping, future upgrades, etc etc, but 2 1/2" is probably your best bet, with maybe a small 2" run from the compressor outlet on the turbo towards the cooler.
The smaller the piping, the less the lag.
Smaller amount of area to pressurize.
It only needs to be as big as the smallest part of your inlet tract.
If the throttle body is only 60mm then 2.5" would be perfect.
BASS OUT
Yeah, your right on the 2.5' SS bends, its just exhaust tubing. I was once looking for 3/8 mandrel bent SS with 0.8mm wall thickness for motorbike headers, that was hard to find. Somehow I got the two confused. duh!
No one was willing to try and mandrel bend 0.8mm wall thickeness tube for a reasonable price, it just crumples up like ally foil.
Lot cheaper, just as professional and this way you can tell all your mates you have custom intercooler piping :)
yeah my m8s rekons he's going to pay for all the piping n shit n e ways coz he just paying me back for sum shit i did for him last year, so ill just take it around to his shed one sat n away we go i gotta get my cooler 1st... does n one wanna sell me one? 450 * 300 * 76 is what im after
go stainless steel man .... Geordi Stainless Steel sales in Chelteham (melb) .. has 2.5inch pipe for pretty cheap ... 90deg are 18.50 ..45deg are 16.40 .. reducers 3" to 2.5inch are 11.50 .. 2.5 to 2.0 are 9.50......ring em up 9553 2000 (131 Herald St Chelteham)
Matt
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
