I've been looking around for a solution or compromise for the situation where I might be maxing out my stock fuel system next time my car hits the dyno. I am aiming for around 400-450hp @ flywheel, and have a 500hp Walbro fuel pump lined up but still have the nasty R33 side feed injectors to contend with.
When I first looked up info on this kind of thing, I found out that 2JZGTEs are low-impedance 550cc side feed injectors but have more recently discovered that those are USDM items, and that Japanese spec ones (a set of which I can get for a very reasonable price) are 440cc high impedance side feed ones - and to my understanding so are R33 RB25DET injectors.
Does anyone concur? And have anyone tried this conversion? Or have any ideas about how hard it would be to make it work?
Thanks in advance,
Dan :cheers:
https://www.sau.com.au/forums/topic/61115-2jzgte-injectors-on-rb25det/
I looked into this a few months ago
Do a search and you should find my thread.
They do not fit directly into the fuel rail, would be too much work.
I am using S15 200sx SR20det manual injectors
Read my post in this thread
http://www.skylinesaustralia.com/forums/sh...ead.php?t=60616
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
