Hi guys,
I just took my car thorugh regency here in adelaide (which is where we take it to get a roadworthy check done to get it registered for those of you who don't know).
I got done for a few minor items, but two major ones were suspension height. It had to be a minimum of 360mm, and i had 340mm, and that is the stock suspension.
Also i got done for this and i don't know what it means. "front and rear track width too wide max 1486f and 1481r", if any of you guys can help with what i should do next it would be much appreciated.
David
https://www.sau.com.au/forums/topic/61191-registration-issues/
LowRollaBoy i think he means 360mm from the centre of the wheel to the wheel arch, not road clearance. Sorry i can't help much oz_cefiro, sure u havn't got cut springs in there. Sounds like they are a bit tight down in SA. good luck.
Definetly not cut springs, i've hired a set from a jap wrecker who does this stuff all the time
