I popped into Jaycar yesterday and purchased the kits for;
The Independant Electronic Boost Controller
products_uploade..._7575.jpg[/url]
Digital Fuel Adjuster
The Hand Controller for Digital Projects
And the RS232 cable to join the Hand Controller for mapping/programming
It has been about 3 years since I built my last electronics kit (a 400 watt sub woofer amp and processor for the home stereo). So I figured I would start with the easy one, the Hand Controller. Instructions where very explicit, quite easy to read and the pictures are very clear. Certainly a big improvement over the DJ stuff (sound and light) that I used to build to help pay the uni fees. Including reading the instructions and the basic electronic theory, it took me less than 2 hours to build the Hand Controller.
I will post up some pictures tonight.:)
https://www.sau.com.au/forums/topic/61207-jaycar-boost-and-fuel-control/
  • Replies 1k
Posted Images
So is that where you got your nick name from ?  From the old DJ years :)
J
Oh no, I was a roady. Not pretty enough to be a DJ. And yet not quite nerdy enough to hide in the back room soldering all day.:cooldance
Watching keenly, been tempted to purchase these kits for awhile.
What solenoid would be suitable for the boost controller for cars that arent fitted with one? AKA cef.
Believe it or not, the solenoid Sillycoon Chump recommend is the Nissan, just like the one on the Stagea. The instructions even have a picture of it. So stick up a "wanted" on the forum, there are plenty of R33 GTST's with EBC's that aren't using their standard solenoids. :)
Shoot why did I say that, now the price will go up. Just like the R32 GTST wastegate actuators, they used to be cheap and plentiful until I opened my big mouth:kick:
I've just ordered a throttle position sensor kit as well from the wholesaler that jaycar buys from. As much as I think Julian's an eccentric english teacher, I really wanna try out his intelligent BOV design.
If anyone needs jaycar kits at wholesale prices then let me know. I don't mind helpin out an SAU hobbyist.
should I start a group buy (it gets even cheaper when ordered in qty's of 5) or are you happy with wholesale...
anyways, enuff hijacking of SK's thread.
A quick picture of the Jaycar Hand Controller on the ashtray lid, can still get to the power socket. Looks OK, easy to mount, bit of velcro on the ashtray lid, some on the back of the controller. It will then be low enough to allow the cup holder to function as normal.
But when I add the RS232 cable..........the plug is nearly as big as the controller itself.
There must be an RS232 flat cable, with a small plug, preferably black. So I can tuck it back behind the controller and in through the ashtray. I asked the Jaycar guys and they didn't have such a cable in their cattledog. Some of the computer experts out there may know of a cable that may be suitable.:P
SK - I think the best way to go WRT cable - is to get a DB25 to DB9 flat converter. Then you get a small DB9 to UTP converter - Run UTP from the HC to the fuel computer and use what ever cables you want at the FC end. It's still going to be a bit cumbersome.
Maybe replace the DB25 on the HC with a UTP connector ?
I've been eyeing those Jaycar kits for ages - Will keen to know the results.
Cheers,
Cheers,
I'll have to check the circuit diagram, but I was told by the Jaycar guys that the communication was 2 way and used a number of discreet connections. I took that to mean I couldn't combine any wiring and had to run 25 discreet links. JE used a flat cable I noticed in the test photos. Looked like the ribbon cable that I use to connect hard drives to mother boards in the PC.
I'll find the photo scan it and stick it up over the weekend.:(
Ahh - I see. I did assume that it was a standard RS-232 connection. If that were the case then you would only need 7 or 5 or 3 wires - depending on how it serial connection was designed.
But yeah - if they are non-standard, discrete connections you will have to refer to the circuit diagrams -
IDC connectors (hard drive cables) might be the go
SK why don't you just hardwire the plug in... ie cut the plug off and solder the cable to the terminals inside the box, and have a small hole with the wire coming out of it.
Yeh thanks! That's a good idea, except I have already soldered the plug onto the board.:(
PS I am not really planning on permanently leaving it in the Stagea anyway. So I might not worry too much.
I'm really interested in how the thing actually performs in terms of spiking, holding boost. More importantly how difficult it is to set up for say an ordinary person.
Well, the theory is;
It can't not hold boost (as long as the turbo is up to it of course) because it can completely stop any boost (airflow) reaching the wastegate actuator. This is because the boost control solenoid (pnuematically) sits in between the plenum and the wastegate actuator. Unlike most boost controllers (EBC of not) that bleed off air and lower the pressure that way. Put another way, Sillycoon Chump's design is in series with the wastegate actuator whereas most other EBC's are in parrallel.
Spiking, is pretty much a factor of the electro mechanical response of the solenoid. Plus how fast the processor can interpret the results and send instructions to the solenoid. Once again Sillycoon Chump's design has an interesting advantage, it doesn't use boost to give feed back, it uses injector duration. This means the boost control processor is not waiting while airlfow is buffered though pipework to a MAP sensor. As soon as the injector cycle changes, it knows the airflow has changed. And that happens once for every two engine revolutions, that's 50 times per second at 6,000 rpm. That sort of response is physically impossible using airflow to drive a MAP sensor.
What is really interesting is the ability to have 2 completely different boost maps with up to 128 load points in each. That doesn't mean simply "high" and "low" boost settings. What it means is I can have the same max boost, but have one boost map (say for wet weather) that brings the boost on slower. I can have lower boost as well if I want, but I don't have to. Pretty cool huh?
I did a fair bit of research before I decided to give these a go, and they have some very interesting features. Looking forward to giving them a real world try out.:D
PS; The interpolation (smoothing) algorythm between the 128 load points looks to be quite effective as well.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
