Oosh is a legend.
It's official I missed the link underneath the db25 connector on the H/C !!!
Wow - I didn't even notice it - thanks Oosh you're a champ.
As for me getting it working earlier than you - I doubt that very very much, since now I'm looking for a solenoid.. and I don't even know if I have one let alone what it looks like!
:P
  • Replies 1k
Posted Images
The solenoid looks like the one in the performance jaycar book thingy for cars. If you follow the diagram, it shows that the solenoid should be used to bleed off some pressure stock. Follow the boost hoses.
I tried to give you a ring mate, but you didn't answer. Good to hear you got it working.
I love the feeling of solving a problem
what about my other part, my turbosmart isn't electronic. Is there great benefit in going to electronic?
This particular design (of electronic) has several advantages, the best one for me is the ability to have ZERO boost pressure at the wastegate actuator. This means (unlike beled valves or other designs of electronic controllers) the wastegate is absolutely closed until you program it to be open. The result is the FASTEST possible boost build that your engine and turbo combination can deliver.
Your Turbosmart is simply a bleed valve, it lets some boost preessure escape so that the wastegate actuator sees a lower pressure. This means you get higher boost. BUT it alllows SOME boost pressure to get to the wastegate actuator, this means the wastegate starts opening long before your target boost pressure. So you get slower boost build.
There are many other advantages (they are in my previous posts) but for me that is the one I personally like the best:cheers:
thanks mate, sounds like a worth while upgrade. currently the car seems to hit boost when it wants to. it's not consistant as to when it does it boost and as you say is pretty slow to build up.
I think I'll buy the IEBC and hand controller. IS there any other option for an EBC at this price point?
cheers
Great work funky - thanks for the groupbuy, no doubt I'll get a few mates in on this.
I have a quick question for S-Kid, or anyone who has this installed and can answer.
With the little T connector and soldered hole they get you to put in to relieve pressure after a "boost event" my question is does this bleed a tiny amount when you're on boost anyway?
S-Kid I think you said you were going to keep it a specific size because you expect to have an exhaust put on - I didn't quite understand the reasoning behind this. Why would a free-er flowing exhaust mean you have less boost stuck in that line? Is it because the assumption is after a boost event it goes out through the exhaust easier?
I'm just not too sure how to get the correct size to make sure I am relieving the pressure necessary, without losing too much.
Ta.
Oosh is a legend.
:P
That's great, hopefully that's the last of your woes relating to the electronics, now on to the pnuematics...
Solenoid: I used a R33 GTST item which was very kindly donated to me by NoZila despite my repeated attempts to give him money. Cheers mate! :P
Hosing: If using a R33 solenoid item you need to go for 4-5mm (5/32" to 3/16") inner diameter (ID) hosing, take your solenoid along and trial fit as the two barbs are very close together and if the hoising outer diameter (OD) is too large you'll struggle to fit both with hose clamps.
T-piece: I got a brass item which was for 1/4" ID hose because i DIDN'T trial fit my hose first, but i stretched the smaller diameter hose over it no worries.
Bleed Restriction: You have several options in order of complexity and cost, solder up the brass T-piece, add a bit of hose with a restrictor, add a needle valve.
I went with second item as i don't presently have access to a drill and didn't find a valve right away (I'm also worried about vibrations changing the opening size).
When i was @ supercheap i found a plastic 6mm -> 3mm adator (for $1 on clearance), the whole inside the 3mm is ~1.5mm, so shoved that inside a length of hose and attached it to the T.
I plumbed it all in last night and it looks a little something like this:
             Atmo (or plumback)
            |   |       ____________
Restrictor-> |/ |      |            |
            || ||      |  Solenoid  |
            |   |      |__        __|
            || ||"T"            /
_____________ | | _________ |    |
         ____| |____   ___/     |
<-- OUT  ___________   ___      |
_____________     _________     |
___________________________ |    |
                       ___/     |
 IN -->                ___      |
________________________________|
Obviously the solenoid is upside down, I disconnected the hose from the actuator and that becomes "IN", then i ran hose from the "OUT" back to the actuator completing the "loop".
I've only set it up very roughly (wires are a mess atm) and made some conservative map settings (very quickly done) but i must say the car "feels" better, enough to not just chalk it up to "placebo effect", boost builds faster and with the stock turbo I'm running the power delivery feels much more progressive.
It's holding 12psi relatively well and doesn't seem to spike over 13psi, I need to get up in to the hills and spend more time on-road tuning, and then some final tweaks on the dyno are scheduled for early April.
Hi SK - Since the IEBC used injector duty cycle in it algorithm to control 'stuff' - do you think that this would work with a diesel turbo ?
Bump ?? I guess that means no-one knows ?? :P
If it is an electronically injected diesel it will work. If it is mechanical injection it won't. How do you tell? If the injectors have wires hanging out of the them, then they are electronic. If there is only fuel connections to the injectors, then they are mechanical. No big deal, diesels work quite well with bleeed valves.:P
It should work as long as-
You have a turbo, wastegate and you "splice" in a solenoid with a "restricter" between the solenoid and the wastegate and you can find your injector wire from your computer.
If you need more explanation PM me or ask here.
I'm going to install this system in my r32 gtst over the easter break, could someone explain why you need to bleed off air from the solenoid outlet? And why you need a restrictor?
Shouldnt the solenoid just stop the air until you hit the desired boost, then let the air through to open the wastegate? Or have a missed something?
Gday Rhett,
This was explained to me, so I can't take credit for having understood it on my own...
Basically the restrictor/bleed peice acts to let off pressure built up between the normally closed solenoid and the wastegate actuator.
When the actuator feels boost pressure (such as when your on boost) it will get to a certain pressure and then "actuate", to move the shaft that in turn opens the wastegate, letting pressure out around the turbine and keeping you at the stock boost level.
When you put in the solenoid as part of this kit, it will be normally closed, so after you've been boosting and take your foot off the accell, the solenoid will shut. This traps the pressured air between the wastegate actuator and the shut solenoid, because that has nowhere to go (as it's not stuck between the actual wastegate itself, only the actuator) it will sit between the solenoid and actuator and keep your wastegate open, which means you will have absolutely NO boost because the wastegate actuator thinks you're on boost, and is keeping the wastegate open.
Hope that makes sense.
i have soldered up the IEBC and hand controller kits and found a solenoid off a blitz boost controller, and I have some questions if any one is kind enough to share their knowledge. Hopefully someone knows some of this!
Would this Blitz boost control solenoid likely be fast reacting and hence require increasing the pulse frequency of the IEBC? Is it likely to have a good duty cycle range?
It has three connections so I guess I block one off?
Any ideas where I can source a brass T piece?
No idea, I can only suggest you try it.
Yep
You will have to work out which is the normally closed port, simply blow into each port and find the one that doesn't flow. Then apply 12 volts and make sure that port opens and block off the one that doesn't have any airflow.
Auto-One, AutoPro, Repco, AutoBarn basically anyone, but SupaCheap (they only have plastic ones).
Hope that is of some help:cheers:
Sorry to deviate a little - but sk, when you put that 1-1.5mm boostrestrictor/pressure leveler in the hose that bleeds air back into turbo inlet (where solenoid used to be) did the boost spike much? I hear people with pneumatic boost controllers having 1-2psi spike. I was going to replace the solenoid with a simple needle valve so I dont wreck the solenoid and then I can adjust boost to 10psi. This should have the same result as you putting this orifice type piece in that hose I would imagine except the hole size would then be adjustable, hence contolling how much air is bled and hence the boost the engine sees. I just dont want boost to spike too much if possible.
By using the standard restrictor as a bleed off, I didn't have very rapid boost build. In fact it was quite gentle, as the restrictor bleeds off the same amount of airflow all the time. Plus it is routed back into the inlet to the turbo which means it has progressive (but minor) vacuum applied to it. Consequently I had zero boost spiking. This method works quite well at 7-8 psi and removes the low boost (4 psi) which is the main reason I did it. I would not be confident for boost levels over 12 psi as a whole new set of aerodynamics are involved.
I don't see why a needle valve wouldn't work the same, but I am not in any way an expert in aerodynamics. The effect of temperature on needle valves should not be underestimated. Again it would depend on the boost target,
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
