  • Replies 1k
Posted Images
Are they the threaded spacers (they look too fat I think)?  The other ones are just like washers (not fat enough)...
I'll finish it off tonight - but did your screen sit completely flat or tilited slightly?
thanks guys
My screen is completely flat. Sorry I can't remember what spacers I used and I can't just take a look as my Controller is out on loan at the moment.
:D cheers :D
The LCD screen is held in place with two screws. One in the top left and one in the top right. These go though the main board and into the case. You have to solder the connections from the LCD screen to the main board.
The spacers go under the main board between it and the case. The top 2 screws go through the LCD board, through the main board through 2 spacers and screw into the case. The bottom 2 screws go through the main board, through 2 spacers and screw into the case.
If you don't put the spacers in between the case and the main board the buttons won't stick up far enough for you to push down, and the LCD screen will have a gap between it and the lid.
Have a look on Page 106 of the Performance Electronics for Cars, if you don't have one, I strongly suggest you spend the $20 and get one from Jaycar.
Hope that helps
:D cheers :)
More importantly - do you have to solder the LCD screen/board to the 14pin header?? I see it is copper lined on the holes in the LCD board so not sure if it needs to be soldered. Doesn't say in the instructions to solder and there isn't rally much of an area to solder to.
Edited by benl1981
SK what is the chance of me sending you some dollars and you purchase both units and you build them for me and put in the same imputs into mine as yours and let me know how much for the service and then send it to me in Darwin. As I am no electronics person. Just a thought may make you some cash on the side.
Cheers ICE
Hey guys i just purchased the fuel controller today, is anyone able to scan me and email me some photos of how to make it to [email protected]??
IF some of you have the user guide online and wouldnt mind emailing me some pages to help me get started it would be awsome.
I just built the hand controller last night and that was easy, but i dont really wana spend more money buying a book i only need for 1 project.
Cheers
Dayne
Cheers ICE
Hi Ice, my hourly rate is pretty expensive and we have race meetings back to back for the next 3 weeks. Then a 2 week break, maybe I can fit it in then. PM me for more details.
:D cheers :P
Sorry to jump in guys, but how effective is the DFA without ignition timing changes?
I'm looking to use it in a tiptronic Mitsu FTO. The increased tuning points makes it more attractive to me than the SAFC, but the Greddy e-manage has an 'auto shift compensation feature' (ignition timing compensation at set shift-up and shift-down points).
How I'm interpreting that is that it would only be of benefit if I use tiptronic mode and shifted at certain RPM levels. The car spends most of it's time in full auto mode anyway, so would that mean it's not really beneficial??
Cheers.
Cheers.
The DFA is as effective as any other AFM voltage bender. They are great up to the point where to tune any (lower voltage) leaner would mean too much ignition advance. That's where you compromise, keep it a bit richer so it is not knocking because of too advance ignition timing.
From my limited knowledge of Mitsubishi auto shift logic, they appear to already have a full set of maps for ignition cut/interupt/retard on gearchanges. So I can't see what the EManage will do, other than stuff up that logic.
The DFA makes no difference whatsoever to the auto shift logic program on Skylines and I see no reason why it would on the FTO either.
:D cheers :P
Quick question guys.
Just about to finish the DFA kit - there is a 4Mhz component that looks like a link from the D25 socket should be soldered to it..is this correct?
Here is a phot from someone else here that I just copied and drew on to show the piece
Thanks
Edited by benl1981
Thanks
That the earth for the case of the 4mz crystal, it has to be soldered to the case.
:( cheers ;)
cool - thanks. I did that anyway.
Just started calibrating it. The trimpot I found hard to regulate the voltage. I was able to get 5.1V for the input then at the test point I just matched it pretty close...and when doing the outlet adjusted to get about 5.1v. SOund ok you think?
Do you guys use the fine or coarse mode?? I think for course mode you have to put the link in..
Thanks
Edited by benl1981
A feww things:
1. The solder doesn't go on the 4MHz device the best - did you find that?
2. I find the test pot voltage fluctuates about 0.1 volt. Is this normal?
Just pulled the kick panel off to have a look at the ECU. I think the R33 pinot must be different to the stagea one. I think AFM is pin 27, not sure about 12volt + pin. You want a non switched 12v right??
WIll be nice if I am able to gain 10-20% power ;)
3. Also - what should I set base timing to before the dyno tune. I think I am at about 17-18 deg BTDC. Manual says 15deg BTDC. Should I put it back to factory spec??
4. Should the link be in to put it in coarse mode or leave it out for fine? THis is in the DFA
Edited by benl1981
3. Just pulled the kick panel off to have a look at the ECU.  I think the R33 pinot must be different to the stagea one. I think AFM is pin 27, not sure about 12volt + pin.  You want a non switched 12v right??
4. WIll be nice if I am able to gain 10-20% power ;)
5. Also - what should I set base timing to before the dyno tune.  I think I am at about 17-18 deg BTDC. Manual says 15deg BTDC.  Should I put it back to factory spec??
Suggestions to your quetions follow;
1. You have to heat it up a fair bit, it's a big heat sink. Not too much heat, just enough to get the solder to flow.
2. Yes
3. The R33 ECU pin outs are definitely different to the Stagea, which is R34 spec.
4. Yes
5. I set mine at 15 degrees, tuned the DFA, all the time checking for pre-ignition while tuning the A/F ratios. Because I had the standard exhaust I couldn't get the A/F ratios lean enough (still around 11 to 1). Later on I fitted the adjustable exhaust camshaft pulley, while I was doing the cambelt service. With 4 degrees retarded exhaust camshaft timing I was able to advance the ignition a few degrees without any pre-ignition. So it is now around 20 degrees. But I figure once I finish the exhaust, I might have to go back to standard timing (15 degrees) to tune the A/F ratios a little closer to 12 to 1.
Hope that answered your questions
:) cheers :D
Thanks Gary. Sounds good. might set it back to 15deg then.
Just to make sure, I have the centre plastic piece removed so all the coil packs are exposed. I am using the wire going to No. 1 coil pack to get the reading for the timing light and unclipping the TPS. Will this give the correct reading? I can’t really use the loop at the back.
Edited by benl1981
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
