  • Replies 1k
Posted Images
If for example you had a standard R32 GTS-T which you put an exhaust,pod,intercooler and this boost controller onto then got your CPU remapped - Would the new fuel mapping alter your boost control? as your injectors are going to be operating at different duty cycles throughout the load range than what you have already set up.
you should remap it potentially yes - but for the most part (if you're not concerned about ramp up and so on) then all u need to do is look at ur boost gauge and make sure its hitting intended top boost, and holding it - if it is, then u can leave a remap for later on
Not sure you understood my question?
I'm going to get a remap! But the sole input to the boost controller is the duty cycle of the injectors!
So when the computer is remapped the fuel map will be altered = Where at a certain load point the injector duty cycle was 84% and after the remap it is now 72% (not as rich as standard). So to my reasoning your previously perfectly tuned IEBC will now be out of whack due to the change in fuel map - [richer in some parts (injector on for longer) and leaner in others (injector on for less time)] Therefor giving the boost controller different input values at different times which the controller will interprit and actuate the solonoid OK but the boost curve would be all over the place!
Then what do you do? Retune it after the map but then your fuel map will be out and you'll be chasing you tail forever and possibly causing leaning out?
Please give me your thoughts. Am I on to something?
you tune it the same time you do your computer - you need to do them together (if you are going to do them both eventually then you should do them at the same time)
you could leave the boost mapping, and depending how much you change ur fuel etc maps, there might not be a noticible difference, but you are right in that potentially you will need to remap it as ur points will now change
main thing im getting at is that the boost wont be as sensitive to changes you make to boost mapping - eg if u remapped ecu then leave boost as is, you might find it boosts slightly later, is slightly higher, tails off a tiny bit or whatever, but it wont be to the point that its not drivable and it might not even be noticable (depending how much ur ecu is changed in the remap)
Edited by NewKleer
hey guys,
just wondering if any of you have used the IEBC on a GTR? what sort of results have you been getting in terms of holding a reasonable amount of boost?
i've got an R32GTR with HKS 2530's on it so I want to run a decent amount of boost to get my money's worth from the turbos.
if anyone has any info/ opinoins for or againts this proposed setup that'd be much appreciated!
cheers,
Alan
hey guys,
cheers,
Alan
Hi Alan, no different to using the IEBC on any car, it works great.
:D cheers :D
  • 4 weeks later...
does anyone know if there are anything similar to the jaycar fuel control kit which works with karmann vortex type air-flow meters? (i.e use a frequency as opposed to voltage) I'm looking for something like this for my Cordia, this would be perfect, but it only lets you use a voltage based scale. I guess an SAFC would be the alternative, but the jaycar kit seems more tunable & i would also use the boost control kit.
Looks like a very interesting kit, and SK's comments are really helpful as always.
You run a slight risk by using a serial boost controller in that a failure of any component means your boost will spike drastically because no pressure is reaching the wastegate. The tradeoff is that the spool behaviour is superior to a parallel bleed type.
Just built the DFA, and all working well.
Only one hiccup... if your changing voltage at an input load, say you hold down the 'double-up' button, after a couple of secs of holding it, it jumps to +128, which is fine. But if I then hold the 'double-down' button, it starts decreasing, but then jumps back to +128, like if I'd been holding the up button.
Anyone else seen this?? Hardly seems likely to be building fault to me, maybe PIC fault. Means to decrease I have to keep tapping button, holding it down makes it jump to +128 every time!
Try the Jaycar Digital Pulse Adjuster, it is like the IEBC in that it takes a pulsed input (from the injectors in the case of the IEBC) and turns it into a pulsed output (to the boost control solenoid in the case of the IEBC). Have a read of the section on adjusting pulses in the book, Performance Electronics for Cars.
:P cheers :dry:
Edited by Sydneykid
No more so than if the wastegate actuator vacuum hose falls off, splits or leaks. In fact, based on the reliabilty of electrical components in the cabin compared to rubber hoses under the bonnet, I would go the other way.
:P cheers :dry:
assuming you know how to build the kit reliably (ie not overheating sensitive components or forming poor solder joints) and you're careful when trying it out for the first time it should be sweet.
The main point of failure would probably be the solenoid. Should be a fairly low risk, I guess if you're paranoid you can always buy a brand new one that's guaranteed to last longer than you will :D
  • 3 weeks later...
anyone u pay to tune it should be able to (ie, they would otherwise be able to tune other things like SAFC etc). its pretty simple
u could do it urself also (just pay for 1hr dyno hire) if you have somewhat of an idea what you're doing (reading this thread would be a good start).
ive tuned mine twice now (second time we blew a tailshaft). hardest thing is getting the load points matched up with RPMS so u know which points to move up/down. just make sure you have someone listening for pinging (often dyno operator/assistant will)
best way to align rpm/load points is tell dyno operator to go thru a run slowly calling out every 500rpm, and u write the load point from handcontroller at that point. then when u look at graph, and see u need to lean, rpm from say 5000->5900, then u look at ur load points and u should be able to tell roughly where that is
Edited by NewKleer
and how much would it cost to get tuned on a dyno, with the tuner doing the tuning ?
how much to tune safc2 ?
havent done any tuning thus far, so not sure, but i did get a quote that sounded tooo high.
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
