  • Replies 1k
Posted Images
Interesting stuff SydneyKid, can the two controllers share a common plug to the h/c?
Or do you have to unplug one and shift the cable to the other when making adjustments?
Just interested becauase I would most likely build them into the same chassis.
Just looking at the circuit diagrams, I would say you can only have one plugged in at once as they use common pins. You may be able to switch the data streams over though, rather than physically unplug the Controller from one and plug it into the other.:D
or get an rs232 switch that you can strip out of its metal box and put into the dash somewhere to allow switching.
sk i have seen flat rs 232 cables we have them hanging off the back of our pcs at work cant figure out what they connect to tho. looks like a ribbon cable with a tiny flat rs232 connector at the end i will try to take a pic
what's the sampling rate of the boost controller?
The data source is one injector, it doesn't matter which one. So the "samples" will be supplied at 1/2 engine rpm, the IC is much faster than that. It will increase as the engine rpm rises, which is coincidentally just what you would want. Perhaps not "coincidentally" maybe the Sillycoon Chump thought about it.:D
everything that you've said so far makes perfect sense. Now, all I;m waiting for before going ahead, is your real world test results to see if the little beauty performs as it's supposed to.
Also, I'll wait to see how many things need to be connected up.
And then next comes the fuel modifyer. hehehe
Cheers Gary
As you can see I have finished building the kits, the boost controller was the last one. It took around 1.5 hours to build. If I get time i will connect them up over the weekend, I will leave the fuel at zero (no correction) until I get time on the dyno. But I might give the boost a tweak straight away. If I do, I will post up the results. Regardless I will do before and after runs on the dyno.
It took me around 3 hours to fully read the instructions and background theory, then build the Fuel Adjuster and calibrate it. Then about 1 hour to build the Controller and about 1.5 hours to build the Boost Controller. All up around 5.5 hours of easy, no rush work. There is a bit of set up (calibration) involved in the Fuel Adjuster. The Controller has no set up, just adjust the display brightness. The Boost Controller has to be set up (calibrated) in the car, but it looks pretty simple.
There are only 8 connections to be made in the car, and the power supplies (+ and - 12 volts) are common, so that's really only 6 connections. I will make them all at the ECU, saves running wires under the bonnet. If someone has access to a good copy of the Stagea ECU pin out, this thread would be a good place to put it up. The connections are;
Fuel Adjuster;
Red = 12 volts +
Black = 12 volts -
Green = input from AFM
Black = output to ECU (where the AFM used to be connected)
Boost Controller;
Red = 12 volts +
Black = 12 volts -
Green = input from injector
Black = output to the standard solenoid
:P
PS; the Jaycar guys asked me to rate the kits when I was in there yesterday. Well I rate them as one of the best kits I have assembled, good instructions with pictures, easy to read, well laid out boards and all required components are included. I am no electronics engineer, and I had no problems. "Highly Recommended" would be my summing up.
Good work SK.
Apparently the Stage (series 1) ECU has the same pin out as the R34 GTT. It certainly has the same plug that's for sure.
Here's a link to the pinouts for the R34 GTT.
http://members.iinet.net.au/~jay77/R34ECUpinouts.pdf
Cheers
J
I though it might be handy if I added the ECU pins I intend to use;
Fuel Adjuster;
Red = 12 volts + * Pin 31
Black = 12 volts - * Pin 32
Green = input from AFM * the cut wire that used to go to Pin 54
Black = output to ECU (where the AFM used to be connected)* Pin 54
Boost Controller;
Green = input from injector * Pin 101 (cylinder #1)
Black = output to the standard solenoid * the cut wire that used to go to Pin 104
I have now fully tested them and the connections are as posted above.:P
Does anyone know if Stageas have peak hold injectors? I am getting erratic signals from #1 injector switching at the ECU, which is usually a sign of peak hold injectors. But I thought all RB25DET injectors were high impedance, usually peak hold uses low impedance injectors. Anyone measured the impedance of Stagea injectors? :)
I remember skylinegeoff telling me that he had to wire in some resistors to his injectors when he replaced them with aftermarket ones so that the injectors worked properly with the signal. He may be able to shed some light on the topic.
Nup. I have some toyota 440cc injectors that are low impedence (3.3 ohm) so I need the resistors to protect the ECU. Daresay it will have little to do with the suspected peak hold facility on the Stag injectors.
Time to throw a big auto multimeter on it SK and sample the injector signal. Oh...and the impedence :P
Maybe time to visit my best friend the electronics engineer, he has a nice scope and the knowledge to use it. I don't want to build a Jaycar peak hold adaptor if I don't have to.:P
PS; I got sick of waiting, so at 4.00 am today I rerouted the vacuum hoses and worked the boost up to 0.5 bar, goes a lot better than 0.3/0.4 bar. Zero cost, 10 minute job.
How, what?? What did you do that cost nothing and only took 10 minutes?
I thought everyone with an RB25DET knew how to do it. You just disconnect the solenoid (vacuum, not electricaly), connect the boost feed directly to the wastegate and use the (standard) restrictor to bypass the desired amount back into the turbo inlet. The standard byspass hole of 1.25 mm bypasses enough air flow for 0.5 bar. Tools needed = one pair of pliers and 10 minutes.:P
PS; If you want more boost you can drill out the bypass, 1.5 mm = more boost (around 0.7 bar) 1.75mm = a bit more (around 1.0 bar). But the Jaycar Boost Controller needs the bypass to relieve trapped pressure between the solenoid and the wastegate actuator. So I don't want to redrill the restrictor only have to solder it back up again.
One thing I've been thinking about. Being an electronic boost controller, what does it use to sence the boost presure ? Does it have it's own map sensor? or does it figure out what it needs to do by going off the duty of the injector that you need to tap into ?
It's also something I need to find out about the Unichip boost control module, does it need a map sensor.. If so I'll have to source a one and install it cause the Stagea's don't have one from factory - no boost gauge..
J
No , not me - I know nothing, and now realise that I know even less... :D
Any links to pics/diagrams that illustrate the bits you refer to? As I said - I know nothing - except how to replace the panel filter! :D I once had a Mk I GT 440 Consul Cortina that I knew what did what and could even fix when minor things went wrong, but now days when I open a bonnet I just go "Hmmm, engine" and that's as far as it gets!
:P
This is the 10 minute no cost boost to 0.5 bar rerouting of the vacuum hoses. Disconnect the two vaccum hoses from the solenoid. Then connect the boost feed (from the cross over pipe on the left of the picture) to a the standard T piece. Connect one side of the T piece directly to the wastegate actuator (on the right of the picture). The remaing connection on the T piece goes back into the inlet via the BOV return pipe (on the standard fitting). Make sure to put the the standard brass restrictor in that vacuum hose to bypass the desired amount back into the turbo inlet. The standard bypass hole of 1.25 mm bypasses enough air flow for 0.5 bar.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
