Ooh, red LEDs :bunny:
Probably the usual IC orientation issue, but I don't have the instructions with me atm...
Do you have the wire link that goes under the DB25 connector (hand controller socket) installed? From memory I think it is installed on the underside of the board or something; I did the same trick and I can't see it in your shot... but I can't see much (as u noticed) TBH :D
  • Replies 1k
Posted Images
Ooh, red LEDs ;)
Do you have the wire link that goes under the DB25 connector (hand controller socket) installed? From memory I think it is installed on the underside of the board or something; I did the same trick and I can't see it in your shot... but I can't see much (as u noticed) TBH :)
checked those i think, and i remember doing the link under the connector
When you say nothing happens do you mean literally nothing? Do the LEDs light up at all? Best to test with the handcontroller plugged in so you can look at its screen. Try turning the trimpots on the IEBC back and forth to see if there is any action.
Are you confident that the ICs are the right way round? and in the right places? If you look closely you will see that they have different part numbers:
IC1 (marked with dot ) cat# EZ8996 KC5387A goes at right angles to the DB25 (handcontroller) socket on the opposite side of the board with the cutout on top - facing the DB25 socket.
IC2 (marked with line) cat# EZ8997 KC5387B goes parallel to and near to the DB25 socket with the cutout on the left.
Note links LK1 and LK3 should be left out.
its all how i have it, just double checked then
holding the wires onto the battery terminals should be enough shouldn't it?
and no, no activities from the led's :D or the display :):(
  • 1 month later...
hi all,
im finally getting round to install my kit - a quick question.
it looks like the vent between solenoid and actuator is open to atmosphere, according to the figures in the kit - is this the way to go, or plumb it back to pre-compressor somewhere?
cheers,
sam
hi all,
cheers,
sam
That's correct Sam, that's how I've been running mine. There is a connection on the turbo inlet pipe (suction side) that I have been meaning to connect mine too just so it isn't hanging around the engine bay but I don't think it matters. It may actually be bad to connect it there... haven't tried yet.
so it runs just fine without plumbback ?
i suppose it's only very small amount of air that's going out of the system post-AFM.
anyone with plumbback care to comment?
cheers
sam
Yep like Dave says it should be plumbed back into the bov return pipe (as yours is a new installation you may have to make a fitting). There should be a restrictor in this line and adjusting the diameter of this restrictor will affect the range within which the solenoid operates so if the duty cycle is too high you can make the restrictor smaller or vice versa.
  • 3 weeks later...
  • 2 months later...
Does any one know were to get one of these tuned on Queensland? I have built mine and want some one to tune it on the dyno It has been calibrated and ready to go.
have you got a boost controller or a DFA? The boost controller doesn't need to be set on a dyno. Is it installed and wired up? Any shop should be able to tune a DFA - in principle its the same as a SAFC and they might just take a few minutes to read the instructions if they haven't seen one before.
if you're in south burnette, from memory there's only one good tuner near you and he's in hervey bay. no idea what his name is though.
seriously though, this is incredibly simplified tuning. Anyone who can tune properly can use this setup and i'd be willing to be that even most n00bs could pull something decent out of it.
  • 1 month later...
Hi all,
Was wondering if anyone in Melbourne who has done this could give me a hand installing the DFA into my 33? I got the DFA and Hand Controller units already assembled, they were given to me when I bought another car awhile back. In return I could help you polish your car.
Cheers,
Will.
  • 4 months later...
To all of you out there using the Jaycar IEBC & DFA's a few questions!
Has anyone had any problems / reliability issues with them after the initial setting up?
Has everyone had an increase in economy as well as a good power hike with this kit?
Would you recomend them?
:blink:
I used the Jaycar IEBC for about a year and it was very reliable. The DFA is a better version of the Apexi SAFC. I would only recommend it for a S1 Stagea, but even then you would need an Apexi SITC to do the timing and a Greddy Emanage would probably be better. For a S2 the Nistune chip would be much better value for money as it does the whole range - afrs, timing, speed limit removal, rev limit adjustment etc.
  • 1 year later...
Just skimming back through the thread here's SK's suggestions:
Hi guys, it is not impossible that is is a bad component, but (based on my experience) it is unlikely. Burnt resistors are a sign of excessive load (going through them), so I would work my way through the circuit diagram and check the components on either side of the resistor.
Let's give it a go using the circuit diagram on page 141 of Performance Electronics for Cars;
It's a 10ohm resistor that sits between diode 2 and and zener diode 2 in the power supply circuit comtrolled by reg 1. So I would be checking the polarity of D2, ZD2 and Reg 1 and the value of the 1000uf, 10uf and 1000nf capacitors. I have marked them with red dots on the cicuit layout below (page 137 of Performance Electronics for Cars);.
I know someone has already suggested it, but the problem is in the power supply circuit, so the first thing I make ABSOLUTELY sure of is that the polarity of the power source is correct. Test it at least 3 ways, such as wire colour, multimeter voltage in and multimeter voltage out. The test voltages are shown on the circuit diagram above.
Hope that is of some help:cheers:
And another couple of tips - make sure you have the exact correct cable to connect to the hand controller and DO NOT switch between maps with out turning the engine off. On my one I made sure of this by by-passing the switch so that I only had one map.
Thanks for the help! However, I cannot see either of the images you posted. Perhaps SAU's photo server is temporarily down?
Really?? I didn't know this! I even have a remote mounted switch in the centre stack so I could switch between boost levels! Dammit. What happens if you do switch between boost maps with the engine running? I've already done this several times, didn't seem to do anything (when it was working LOL)??
Also, to try and stop this thread getting any longer, if you wish, you can post replies into my own problem thread here. Thanks!
Also when you say "exact correct cable" do you mean there are other similar types? I've got a cable that fits perfectly and passes all data through, but are you saying there are copies or others that don't quite fit?
Edited by benro2
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
