quite a coincidence i turned up and saw your ten eh.. that was the first time i had been to watch the drags at all.. (and wednesday was my second visit and first run)
ill check out the videos now one just finished downloading..
thanks again for the advice, i think i will also turn up again in a few months (cant be taking time off every week!) for another run. in the meantime ill have a go at a trackday if one comes up...
ps kenny, are you sure your turbos are large enough?
Holy farking christ, Kenny!
I love it when you talk like that Adrian. ;-)
Cool, here are some direct links to the movies. You need DivX to watch them I think.
25th August 2004
First ten second pass incar, stand File size 15.8M Codec: DivX Pro 5.2
First ten second pass stand File size 9.8M Codec: DivX 5.1.1
18th August 2004
Five passes on street radials File size 65.7M Codec: DivX Pro 5.2
In car showing boost gauge, speedo and tacho File size 9.8M Codec: DivX 5.1.1
28th July 2004
Three easy pieces File size 24.8M Codec: DivX 5.1.1
Alternate takes of wins vs Raima and Mopar Boy File size 15.5M Codec: DivX 5.1.1
Racing Raima File size 17.7M Codec: DivX 5.1.1
Racing Mopar Boy File size 24.8M Codec: DivX 5.1.1
21st July 2004
21st July passes File size 30.6M Codec: DivX 5.1.1
14th July 2004
14th July passes File size 32.0M Codec: DivX 5.1.1
Obviously the Winter months are when the badass contingent comes out to play. Sounds like you've been bitten by the bug!
Hehe. The new turbo is mocked in place inthe foreground, the old turbo (the one I used on the ten second pass) is held by Herbert in the background.
M Coupes only need one turbo to run you know!
Kenny,
Are you gonna skin the rear bar now it's lightened?
What dash are you using?  Old OEM one or fabricating an Aluminium one?  Motec???
Turbo specs for new one?
Adrian
Adrian, stock bodywork will be replaced, it's just off to fit up the parachute anchor.
Using a Stack dash with a Stack boost gauge, Autometer shift light and warning light. Erik will work out how to fit all that shit into the OEM dashboard.
Staying with the BMW ECU with piggyback.
Running a larger Garrett ball bearing turbo now.
Your TS seems very low for the mods you have. I would put your car on a dyno for a tune
i might get it checked out in a while, i got the car in its current tune, it feels right for what it is... it felt quite slow that day i think because of the heat...
but yeah i know that other cars with similar or less mods have higher mph. i know the motor is good though as i have checked compression so it cant be that..
Yeah that time seems very slow for the mods.
I ran a 13.9, 2.2 60ft'r at 205mph with 'just'
- Front Mount
- 13psi
- Turbo Back Exhaust
- POD FILTA BRO!
No suspension mods, and on 235 Marshal Racers (Very very poor tyres)
The morning I went down the strip I had it dyno'd and there was a problem, it wouldn't get over 100kw, the crank angle sensor was full retarded and we only knocked the CAS forward so I could have more power, ran again with 169kw
An as benm said, you really do have to drive it like you stole it, don't be scared to go that extra step you don't on the street :D
- Front Mount
- 13psi
- POD FILTA BRO!
An as benm said, you really do have to drive it like you stole it, don't be scared to go that extra step you don't on the street :P
mate trust me im not scared to drive the thing hard :P :P
Doing fine , i still have the trap speed on him though .
I don't think i'll be doing anymore to this car , i'm waiting for my r34 gtr ( its in Osaka waiting for a ship ) .
Mick should be a bit quicker next time at wsid , new spark plugs fitted and spark plug cover off , thats got to be an extra .2 - .3 sec quicker !
When are you going there next ?
Good to here about the R34 on the way. Mick's Skyline will definitely improve ET and trap speed with the spark plugs. Imagine if he gave it a wash!
We will be out when this phase of build on the M Coupe is completed. We will have to run the new engine in before the final tune as well so we should be out again April-May 2005.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
