Trust Stu and I to hold up our end of the bar at the jerra 2nite: all of your absences have been duly noted,,,,,,,Sinista: very disappointed in you, but I had a beer for you (and everyone else too!!!!)
Thanks Gal + Stu, I was a very dehydrated today . Lost a lot of liquid after last nights BIG effort :headspin: . Where did all that burboun go? Ta Jayce n Erica for taking my line home guys. You had "Run Ya" follow you out for a drag up the strip.
I didn't see your limey one on my way past around 7:30 and back thru about 9ish or I would certainly have dropped in. So I just did the grocery shop instead and the Jerra is still rocking.
I'll be down for Sat arvo/eve.
    • United E85 is always 85% ethanol. At least it claims to be. But that goes out of the window about thirty seconds after you put a tank of it into your car and can't do the math to determine if you have 76% ethanol, or 47% ethanol or 26% ethanol because you put 33L in, then 16L in, then a full tank of 98, then "Some" E85. Ethanol tunes that aren't full flex or full E85 all the time are just absolutely a waste of time. Don't be stupid and ruin your car.
    • I don’t mean this in any negative way. But, if u are after this type of data why don’t u have a flex fuel sensor?
    • So what now? Enjoy it and go cruising or more modifications? Few meets/cruises happen in the west every now and then, should definitely take it out.
    • The issue still requires a human to get all the logic right, and each thing being done takes up processing power. Meaning less processing power for other tasks to occur too. It also typically means a team of size 10, is working one everything, vs 5x teams of 3 working on separate products, so less man power to review and perfect it all.   That's the typical issue of AIO. It's also why manufacturers of cars even split tasks out into separate systems, and share data as required
    • Lol, i have and you can buy them in adelaide more just curious if anyone has tested this one in particular
