During and after general production, a handful of special models were released in small numbers. These rare cars generally featured a small variation from the normal, and seemed to be more like test models than anything. The Autech R32 is an example of this. The Autech R32 was tuned by Autech and was basically a four door R32 GTR, without the turbos, as it housed an RB26DE in its engine bay and an automatic gearbox. You can deduce from the name that the engine was a 2.6 litre DOHC EFI in-line six normally aspirated variant. Very good for pulling trailers since they have tonnes of torque, perhaps the Autech would make a race car tractor? or nice non-turbo family touring car See Autechs page for more info.
Model E-HNR32
Dimensions 4580ױ695ױ360 mm
Weight 1480kg
Engine RB26DE
Power 220PS /6800rpm
Wheel 205/55R16 88V
search for RB26DE for a list of all the threads covering this car and its engine. There was even a thread from about a year ago that was recently dug up about the RB26DE engine for sale at a wrecker in adelaide or somewhere.
There is an actual limited series of auto GTR's released by a tuner (can't remember the name tho). They all had "official recognition" papers, which are the jap equivalent of an engineer's certificate. But they weren't autech N/As
^^^ Shan I think they were responsible for the R32 4-Door GT-R aswell? You know the one...
Btw, there was an R32 Autech Version for sale at Yahoo JP Auctions for about 1,500,000 yen... I'd get one if I knew who could do the auto -> manual conversion here for reasonable cost.
i have some brochures for that car, only the people who understand japanese will be able to read it but theres a few pics to look at.
Half of the Autec r32 and the other half an R32 GTB-4 ( rb26dett gts-4 sedan?)
i just got back from Japan and bought that mag :P
there is one moded N/A GTR, with compression rate rise to 12:5:1, with 100 shot NOS.
pull 380hp@9800rpm with a 10000rpm redline.
Then they race it with some similar hp light mod GTR, and it win for about 1 sec in a lap.
they claim the response is a lot better
there is a dude in the GTR Owners club in japan who owns an R32 GTR which has been converted to N/A!!! lol yes believe it or not he's converted the RB26 engine to an RB31 N/A engine. goes like its nutsack was being bitten by a gerbil too.
Maybe rezz or someone who's a lil more active in GTROC-JP can contact him and find out more.
Completely off topic, but I just noticed the stick under the rear-view mirror of the R32 AUTECH Skyline (in the scans posted -- see http://www.skylinesaustralia.com/forums/at...achmentid=28810 -- its a white 4 on a red background).
What is the signficane of the sticker?
LW.
oh is that off a website? hmm might have to buy the catalogue then... one of these days I'll scan em all in and then sell em... its becoming an expensive habit... datalogue collecting.
  • 4 weeks later...
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
