Hi
I have a SAFCII which has been dyno tuned on my car & runs a dream but i dont think i have a knock sensor connected up to it because the reading from the display is always 0.....
I have no idea what they look like or where they're connected, all i know I'd like one & i'll get my mechanic to install it for me.
So yeh, where can i buy a knock sensor to connect up to my SAFC?
Thanks, :(
https://www.sau.com.au/forums/topic/61249-knock-sensor/
Hi
Thanks, :rofl:
Your engine will have a knock sensor built in, two infact I think. No idea of the SAFC connects to these or whatever, never used one.
https://www.sau.com.au/forums/topic/61249-knock-sensor/#findComment-1157767
I'll ring up the place which dyno tuned my SAFCII & ask them if they can connect it. I remember the guy saying when he dyno tuned my car on Optimax fuel that it was detonating slightly @ 12psi, he said you wouldnt know it but i did because of the knock reading I had. He would have been using his equipment to monitor the knocking.
https://www.sau.com.au/forums/topic/61249-knock-sensor/#findComment-1158300
Well i solved my own problem today.
I downloaded the SAFCII manual off the Apexi site today & went into the Sensor Check on the controller. Yay... i do have a working knock meter, it was displaying raw data. The next was to set it. So i went into the Set Knock & held the rpm at 1500 to get 115 then 3500 rpm to get 117. These were done in neutral as your're meant to & is the raw figures.
Sweet so the knock display now reads around 8 - 11 when ideling @ 700 - 800 rpm. But once i start moving & get above around1500 rpm the knock reading goes to 0. I thought it would still show something higher than 0 so I wound the boost to 12psi & gave it some for a few minutes. I still got nothing, was always displaying 0. The air outside was cool too as for its the end of the day & its been raining.
Im just wondering what figures do other people with SAFCIIs get?
I did the Set Knock feature twice, when i first did it the raw figures were more like 95 - 98. 5 minutes later after mucking around revving it in idle setting the knock the figures went up to 110 - 120.
All of these setting were done after the car already being driven for 30 minutes.
I dont know if 0 is just really good or what’s the deal? I have had the SAFCII dyno tuned & I run 12:1 A/F Ratio's. I might try the Set Knock again on a warmer day with a more average outside temperature.
Any one with experience setting their knock & their display figures would be much appreciated.
Thanks, :cheeers:
https://www.sau.com.au/forums/topic/61249-knock-sensor/#findComment-1164249
That sounds perfectly normal to me mate... Mine does the exact same thing... If / when it pings, you will get a reading of around 80+ for the duration of the pinging...
A reading of 0 whilst accelerating is fine and to be expected with the SAFCII...
You may find your idle knock reading will go as high as 30 when the car has been driven for more than a few hours during the day... This too is normal...
https://www.sau.com.au/forums/topic/61249-knock-sensor/#findComment-1164274
Owww sweet sounds good then. Yeh it will be good to know if my engine is detonating now so i can look after it. I was thinking of getting an Air/Fuel ratio gauge too.
Also, have you played around with the Warning setting in the SAFCII, supposedly you can get the SAFCII to notify you or react somehow when a parameter you set is exceeded *eg too high knock figure*. I'll have to have a good read of the manual again.
https://www.sau.com.au/forums/topic/61249-knock-sensor/#findComment-1164311
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
